Old 01-18-2017, 06:48 PM   #1
vht
Dash Pads
Anyone used Summit Racing's dash pad? That seems to be the cheapest I've found. It's either that or find a decent used one and put a cover on it. I can't see spending over $320 for one, can't afford that.
vht is offline   Reply With Quote
Old 01-18-2017, 07:01 PM   #2
Jeff's bowtie's
Re: Dash Pads
I put one of there urethane dash pads in my 78 looks good and fit nice for the money you can't beat them they are from dashes direct
Jeff's bowtie's is offline   Reply With Quote
Old 01-18-2017, 08:29 PM   #3
vht
Re: Dash Pads
Thanks, I should have said the urethane was the 1 I was looking at, $227. I can't find a used one around here that I could put a cover on. They are a $100 for them.
Old 01-18-2017, 08:31 PM   #4
vht
Re: Dash Pads
I wish I could because I need the insert for a/c also.
Old 01-20-2017, 05:36 PM   #5
dragonball98312
dragonball98312's Avatar
Re: Dash Pads
Pm
dragonball98312 is offline   Reply With Quote
Old 01-20-2017, 05:40 PM   #6
gmachinz
Re: Dash Pads
We have a vendor on here now who reproduces them-better than anybody else from reviews I've read too on other forums. cheyennepickup is his ID-I plan on trying one of his 81-up Dashpad's....prices are about $339 if I recall.
gmachinz is offline   Reply With Quote
Old 01-20-2017, 06:25 PM   #7
vht
Re: Dash Pads
A member on here PMed me, he has a perfect 73 to 78 I think he said. I was thinking they had to be 81 to 87, am I right on this? Mines a 84.
Old 01-20-2017, 09:13 PM   #8
TKCR
TKCR's Avatar
Re: Dash Pads
I believe the only difference is, is that on the 80's, there the cutout for the vin plate on the left side by the windshield. The later models, there is no cutout. Just not sure when it started.
I hope I'm right on this info. Maybe someone else will chime in, if this isn't right.
Old 01-20-2017, 10:25 PM   #9
vht
Re: Dash Pads
For some reason I was thinking they were different around where the cluster cover goes. I may be wrong, happens alot here lately.
Old 01-20-2017, 10:30 PM   #10
TKCR
TKCR's Avatar
Re: Dash Pads
No, I think you maybe right.
Old 01-21-2017, 10:24 AM   #11
WyattTX
Re: Dash Pads
I got a dashes direct dash pad for my '85 from LMC other than some minor trimming, it has held up well and looks very factory. I painted it with Colorbond to match my interior. You can see it in my thread located in projects and builds the 73-80 cab and the 81-87 cab are identical. If it were not for the different instrument clusters, you could use interchange dashes with no modification. If you are changeing your instrument cluster and dash, it should be a bolt on application.
WyattTX is offline   Reply With Quote
Old 01-21-2017, 10:40 AM   #12
flashed
Re: Dash Pads
I bought a new one for my 74 from Summit ,have not yet installed it but it looks great ,good quality .
flashed is offline   Reply With Quote
Old 01-21-2017, 11:37 AM   #13
Jeff's bowtie's
Re: Dash Pads
I think 73-78 vin tags are in the door jam and 79 & up are on the left dash top corner
Old 01-21-2017, 07:15 PM   #14
MikeB
MikeB's Avatar
Re: Dash Pads
My 82 has a cracked, cheesy aftermarket plastic cover, and I have been trying to determine which way to go. Found these comments about the OER urethane pad sold by Summit:
https://www.summitracing.com/parts/o...31898/reviews/
Comments range from "fit like OEM" to "terrible fit". So what' a guy to think???
BTW, how do the vinyl and urethane pads differ?
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-28-2024, 12:30 PM   #15
76on44s
Re: Dash Pads
he want to sell? color?
76on44s is offline   Reply With Quote
Old 02-28-2024, 06:37 PM   #16
TKCR
TKCR's Avatar
Re: Dash Pads
That was clear back in 2017.
Old 03-09-2024, 09:35 AM   #17
Pontiac1976
Pontiac1976's Avatar
Re: Dash Pads
Jeff's bowtie's
Re: Dash Pads
We have a winner
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
