Old 01-24-2017, 12:01 PM   #1
2B32
Goodbye Edelbrcok Carb, Hello Holley TBI!
After weeks of tinkering with my carburetor, I have made my carb settings worse and better, but I just can't get it right. I know some guys on here can tune carbs in their sleep, but I lack the skill set, and patience, to tune my carb well on my own. So, I've decided to upgrade to a Holley Sniper TBI. I want something I can jump in and drive anytime without worrying about it, and this seems to be the best semi-budget friendly option.
2B32 is offline   Reply With Quote
Old 01-24-2017, 12:14 PM   #2
onebigjohn
onebigjohn's Avatar
Re: Goodbye Edelbrcok Carb, Hello Holley TBI!
I'm going to follow this.....
I have been looking into the Endelbrock TBI and FI-Tech also both are more money. Cant wait. Please post the pics!
"I pawned my Hanso"
"Hold my beer, Watch this"
onebigjohn is offline   Reply With Quote
Old 01-24-2017, 12:41 PM   #3
weq92f
weq92f's Avatar
While I don't have direct experience with this TBI setup ( Holley ), I have some with MSD's offering.
I suggest you get the Master kit containing everything you need. That is, unless you already have a high pressure, electric fuel pump and all the plumbing for a return line and regulator installed. This way, Holley will support and troubleshoot your entire system.
If possible, build it out so you can attach and run the "hand held" programmer inside the cab while driving.
Use an anti-heat-soak spacer between TBI and intake.
Good luck and happy EFIn,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-24-2017, 01:03 PM   #4
2B32
I plan to get the master kit, but they are currently on backorder so I'll have to wait 2-3 weeks.
Old 01-24-2017, 01:29 PM   #5
Z10
Z10's Avatar
I also have a little experience with FI. I installed a F.I.R.S.T. TPI unit about two years ago and now have 10k miles of trouble free driving on it. You can see the install on my build thread below. I think you'll find from a cost perspective it compares very well with Holley MSD, Fast, etc.
https://www.firstfuelinjection.com
I also have a FiTech TBI installed on my 69 Camaro and it's working just fine also. It's pretty straight forward and less expensive.
http://fitechefi.com
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-24-2017, 03:10 PM   #6
Tdrcreyn4
Tdrcreyn4's Avatar
subbed
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 01-24-2017, 05:26 PM   #7
kenmosher
Another quick tip ...
Do the fuel injection piece first and get it tuned out a bit before adding in the ignition timing function (you also need a compatible distributor like the Holley Dual Sync or one of the MSD Magnetic pickup Dizzies that have the output for the trigger.
It's much easier to get the FI part up and running and THEN add in the ignition piece to "fine tune" things. You'd be surprised how much the ignition piece can help with idle and part throttle stuff.
kenmosher is offline   Reply With Quote
Old 01-25-2017, 01:03 AM   #8
el_fantasma
el_fantasma's Avatar
Subscribed
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
Old 01-25-2017, 01:10 AM   #9
ARCTICFRONTIER
Subscribed! I'm really interested in a Holley Sniper as well. Curious to see some of your thoughts on the system.
ARCTICFRONTIER is offline   Reply With Quote
Old 01-25-2017, 11:49 AM   #10
MLB57
MLB57 is offline   Reply With Quote
Old 01-25-2017, 11:52 AM   #11
MLB57
I can suggest that if you are replacing the intakes a single plane that is what Holley recommends and I had to add a 1" spacer on my dual plane to get any kind of idle quality. Make small adjustments as you go
Old 01-25-2017, 11:55 AM   #12
James the III
I'd check.. as I'd think the truck vortec oem distributor or computer controlled hei could be used..
James the III is offline   Reply With Quote
Old 01-25-2017, 08:16 PM   #13
MLB57
They stopped recommending the small cap and msd. distributors having compatibility problems. Check out the Holley forum on terminator there is a lot of good information
Old 01-25-2017, 09:27 PM   #14
James the III
Originally Posted by Z10 View Post
If it was not for the crazy cost for a TPI vortec intake .I'd be doing this as the TPI makes killer torque and would go with my ramjet cammed vortec350 nicely.
power under the curve is where it's at on a truck
Old 02-25-2017, 10:09 PM   #15
2B32
Quick update.
My kit arrived this week, so I pulled the carb today. I noticed the vacuum line into the Sniper was hitting the vacuum fitting running from the brake booster. I tried to seat the fitting a little more to make clearance and cracked my intake. So, now I have a bunch of new parts just laying around until I can get a new intake. Aside from the major suck of cracking my intake I learned someone did a horrible job of seating the old intake, and even used some sort of liquid sealant in places. It's a setback for sure, but it's not the end of the world.
Old 02-25-2017, 10:32 PM   #16
RUN GMC
RUN GMC's Avatar
Quick update.
Pardon the expression, seems like a lucky break for you....efi is sensitive to excess air affecting the true oxygen reading.....believe your fine turning would have been effected.....when I get my Holley Sniper set up Im going to pull the intake and make sure gaskets and sealant are properly done and add exhaust gaskets too.......
RUN GMC is offline   Reply With Quote
Old 02-26-2017, 01:33 AM   #17
CastIron
CastIron's Avatar
Exactly! It seems like hardly anybody understands this. They only see peak hp.
CastIron is offline   Reply With Quote
Old 02-26-2017, 07:45 AM   #18
GR8-68
GR8-68's Avatar
I am also going with the Holley sniper but I am also using the sniper intake with it. The bad intake seal may have been your main issue in the beginning more than the carb.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 02-26-2017, 01:21 PM   #19
68bowtie
68bowtie's Avatar
interesting. is the sniper kit applicable to a gen IV 396 with a moderate street cam and a performer intake? i was planning on a 750 carb with elec choke and vac secondaries. what specifically will the viper kit add/detract from that setup?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 02-26-2017, 07:05 PM   #20
Z10
Z10's Avatar
James, give FIRST a call, the set up I got included the manifold, runners, throttle body, injectors, wiring harness. Very complete. for around $2100. Pretty comparable to other TBI systems.
A stock TPI set up will suport about 300hp, the FIRST TPI will support around 600hp. The runners are much larger than stock.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-26-2017, 08:09 PM   #21
weq92f
weq92f's Avatar
The FIRST looks great! Reminds me of a friends camaro from back in the day!
Mech fuel pump though? Using that to feed a pressure tank?
-klb
Old 02-27-2017, 01:18 AM   #22
Z10
Z10's Avatar
-klb
Yes, I kept the in cab tank and a buddy of mine built a surge tank which is fed by the original mechanical pump and sits behind the battery. Inside the surge tank is a corvette high pressure pump which feeds the fuel rail. You can see pics in my build thread.
The system/engine/drive train now has 11k trouble free miles on it. Runs better than great.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-28-2017, 12:17 PM   #23
weq92f
weq92f's Avatar
This article is almost 12 months old but it does give a great breakdown of the available EFI TBI systems ranging in price from 750 to 2000+.
http://www.superchevy.com/how-to/eng...-market-today/
-klb
Old 03-30-2017, 10:43 AM   #24
2B32
UPDATE: Goodbye Edelbrcok Carb, Hello Holley TBI!
I finally got my sniper master kit and installed it. The kit was complete with everything I needed. The install itself was pretty easy; I'm not a mechanic by any means, but I was able to do the install myself. At first, the engine was running extremely rough. I have no idea why, but I went through the startup wizard again and the truck started and ran well. After getting the engine up to temp, and adjusting some parameters I went on a test drive. Initially, the truck ran perfectly, way better than it ever did before. About half way through the test drive the handheld froze up. the truck still ran ok, but it didn't run as well as before. I was switching through screens as I was driving so I may have overloaded it with commands. After I parked and cycled the key the handheld worked fine again.
My only problem now is hard start when the engine is hot. I have adjusted the timing a little, but I haven't found the sweet stop yet. I was told I should get everything running well before I swap in the Holley Dual Sync Distributor, so I have a little fine tuning left before I make the change. I'll post again when I have everything completely installed.
Old 03-30-2017, 11:31 AM   #25
MLB57
I had issues with the touch screen freezing up sent to Holley twice and they could never find the problem. Adjust your after start enrichment one lesson I learned was to make small adjustments drive it for at least a 100 miles to let it learn before making a lot of adjustments
