I have my truck lowered 3"/5" inch and now the rear is about an inch lower then the front. Most of you with lowered truck have the rear 2 inches lower then the front[2/4 3/5 4/6} and then it's level. How is this possible?
------------------ 72 C10 lwb fleetside 383/350[transgo] B&M shifter 3"-5" lowered 17" Torq Thrust II with 275-55 and 285-60 Pirelli Scorpion Zero's 96 Peugeot 106 1.6 aut dailydriver [don't laugh it's cheap] DUTCHMANS DRIVE-IN Den Haag The Netherlands "NO MISTAKES NO PROGRESS"
06 BMW 330d aut touring full option 83 Jeep CJ7 360 aut sold 71 GMC Suburban 67 Chevrolet C10 stepside 54 Ford F100 sold 49 Chevrolet coe 48 Ford f6 coe Strijen the Netherlands "NO MISTAKES NO PROGRESS" |
Long Lost Member
I have a 3/6 drop on my truck and the rear is 1" higher than the front. I dont understand how your rear could be lower than the front if you only have a 5" drop on it. Are you sure that no other drops were previously done? Do you have pics of how the truck sits? There are pics of my trucks stance on my web site in the sig.
------------------ 1970 C10 LWB -Worked 350 -Dropped -Tangier Orange Paint Visit my Web Site: www.low70.com College student at Clemson (SC) Home in Langhorne Pa
Tony 1970 C10 LWB -14.09 @ 96mph Web Site 1995 Eclipse GSX -15.46 @ 88mph (stock, not for long) College student at Clemson (SC) Home in Langhorne Pa |
User and Abuser
I got a 3/5 and the it is definitely raked...the rear is at least 2 inches higher than the front...Sorry I have no idea how that could be possible...
------------------ 72 chevy in black prima...350sb, performer intake, 1405 carb, Speed Pro cam, double-roller timing chain, headers, HEI, professionally built TH350
RIP.... '99 Sierra 2x '93 Sierra 4x '72 C-10 Back in business: 68 C-10 lwb |
Out of the carpool lane.
could be a number of things-new springs in front which haven't settled, heated springs in rear which sag; tell us more info; what size engine, what springs, coil, leaf, new, old, lowering blocks?
------------------ 68 Camaro,250(No,I'm not putting in a 350!) 67,LWB,250(Again, I'm not putting in a 350!) a work in progress "Praise The Lowered"
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
I have the 3"/5" coilsprings with Doetch-Tech shocks from CCP. The truck was plane stock before the lowering with all the original parts on it. Can it make any difference if I put the coils upside down?
Here are some before and after pics. Perhaps it looks like the after truck is level but it defenitly is about 3/4 to 1 inch lower in the back. ![]() ![]() ------------------ 72 C10 lwb fleetside 383/350[transgo] B&M shifter 3"-5" lowered 17" Torq Thrust II with 275-55 and 285-60 Pirelli Scorpion Zero's 96 Peugeot 106 1.6 aut dailydriver [don't laugh it's cheap] DUTCHMANS DRIVE-IN Den Haag The Netherlands "NO MISTAKES NO PROGRESS"
Long Lost Member
Are you sure you measured properly? Where did you measure from on the truck, and was the truck on perfectly level ground when you measured? You truck appears to have almost the identical stance as mine and my rear is about 1" higher than the front, measured from the bottom of the body to the ground (lowest point of the body just in front of the rear wheels and just behind the front wheels).
This could be another shot in the dark, but I noticed your tire size-measure on level ground the difference in height between front and back. Perhaps this is it? Also, there is a correct way to install these springs. If I recall correctly, the small loop goes on top. Hope this helps.
Hey BadAzz for the moment I can't measure my truck because it looks like this
Should be back together in about 3-4 weeks and guess Tony... it will be orange [pearl]. And Brad, all the tires are the same size and I will be checking how I mounted the springs. Thanks for your time guys. ------------------ 72 C10 lwb fleetside 383/350[transgo] B&M shifter 3"-5" lowered 17" Torq Thrust II with 275-55 and 285-60 Pirelli Scorpion Zero's 96 Peugeot 106 1.6 aut dailydriver [don't laugh it's cheap] DUTCHMANS DRIVE-IN Den Haag The Netherlands "NO MISTAKES NO PROGRESS"
User and Abuser
As said before, the only guess I could give is that the front springs are not properly seated, which usually occurs where the top of the spring sits...Jack it up, and make sure that the spring is straight up while lowering it (don't put your fingers in between the coils while lowering, that really sucks). Good luck, and your right it does look a little too level to be correct...
Oh yeah, one other thought, maube they sent you the wrong springs, like 1" or 2" front springs??? ------------------ 72 chevy in black prima...350sb, performer intake, 1405 carb, Speed Pro cam, double-roller timing chain, headers, HEI, professionally built TH350
Maybe you were sent the wrong height springs or the wrong engine springs.... If you have BB springs with only a SB on it it will probably sit too high. BTW you did measure it with the all the body panels on right? Dumb question but you never know. Other than that my only guesses have been covered already. Good Luck. CoryM
------------------ 1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070/
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
