Old 01-25-2017, 01:53 AM   #1
Keith6987
Should it be welded?
I am replacing my floor pans and rocker boxes. I noticed the connection between the underfloor brace and the firewall brace is not welded on either side. Is there a reason this area is left to "float" or is it supposed to be welded? This is in front of the front floor body mount.
Keith6987 is offline   Reply With Quote
Old 01-25-2017, 08:44 AM   #2
1972 Jimmy
1972 Jimmy's Avatar
Re: Should it be welded?
When I redid my 1972 Jimmy. Those two pieces showed signs of five or six factory spot welds. The passenger side of mine, all six spot welds were broken and I had to plug weld them back together. After doing this it really made the fire wall alot more ridge.
1972 Jimmy is offline   Reply With Quote
Old 01-25-2017, 10:18 AM   #3
jaros44sr
jaros44sr's Avatar
my spot-welds were broke off on mine as well
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-26-2017, 05:39 PM   #4
cleszkie
cleszkie's Avatar
I need to check mine now! Anything to stiffen up the tub is a plus in my book.
cleszkie is offline   Reply With Quote
Old 01-27-2017, 01:52 AM   #5
Keith6987
Thanks for the input guys...I wanted to check before I melted them together.
