Old 01-26-2017, 10:14 AM   #1
AnobleL74
66 c10 back up lights help needed
my 66 has back up lights installed but no wiring at all.
it has an Ididit column with a backup switch installed on it at the bottom.
need help on where to route wiring and where to hook up under dash.
thanks Allan
AnobleL74 is offline   Reply With Quote
Old 01-26-2017, 11:13 AM   #2
vince1
Re: 66 c10 back up lights help needed
Just to get this started and my info could be wrong because it has been a couple years since working on mine so just some questions rather than answers.
Is there a spade on the fuse block for back up lights?
Is there a free wire for back up lights in the ribbon of wires running along the frame rail to the back?
vince1 is offline   Reply With Quote
Old 01-26-2017, 12:22 PM   #3
PGSigns
PGSigns's Avatar
Check the pin on the column for power with shifter in reverse and the ignition on. If it has power on it I would run a new wire to the lights in the back. The lights should have a single wire coming out of the so you need to make sure the cases have a good ground path.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-26-2017, 02:21 PM   #4
jtrichard
Third photo post #4 top wire on right (one with NO fuse JUST above where it says B.U. LPS.) is where power comes from for BU light switch on column .... http://67-72chevytrucks.com/vboard/s...d.php?t=423593
jtrichard is offline   Reply With Quote
