Old 01-27-2017, 10:16 AM   #1
bjkttr
bjkttr's Avatar
How many of your guys running a step notch?
I am thinking of putting a step notch on my 65 short box build. Can I see pictures of anyone that has one? Did you build or buy yours? If bought where did you get it from?
bjkttr is offline   Reply With Quote
Old 01-27-2017, 11:17 AM   #2
343CA
Re: How many of your guys running a step notch?
I currently have a step notch that was bought from CPP. You can bolt it in then weld the edge after middle is cut out. This has not been put in yet so no pictures. A rule of thumb is a 5 inch or more rear drop needs to have shocks relocated/angled and sway bar link replaced or extended.
343CA is offline   Reply With Quote
Old 01-27-2017, 11:33 AM   #3
LVPhotos
LVPhotos's Avatar
Why? How low are you going? Bags or Springs? I cut my 62 frame and don't use it. My shocks keep it from going in at full drop to keep exhaust from hitting. Besides the rear comes in contact with bed wood first.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-27-2017, 12:13 PM   #4
bjkttr
bjkttr's Avatar
I will be running air ride. I also like the idea of the added strength of a step notch over a cnotch.
Old 01-27-2017, 12:16 PM   #5
LVPhotos
LVPhotos's Avatar
The 62 frame is boxed right there. No out of box parts for notches. Porterbuilt is only one with x frame notches.
Old 01-27-2017, 05:42 PM   #6
Cris
I recently bought a 1963 short fleet so I'm new to these trucks. I am planning to lower mine, but from my measurements, a notch isn't much help. As LVphotos pointed out, the rear end pumpkin hits the bed about the same time the axle tubes hit the frame. From what I could see, unless you are going to relieve the area under the bed for the pumpkin, notching is not much help.
Cris is offline   Reply With Quote
Old 01-27-2017, 10:51 PM   #7
rvrfoot
This is from brothers.Name:  20161130_084107.jpg
rvrfoot is offline   Reply With Quote
Old 01-28-2017, 01:06 AM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
I bought one from CPP looks exactly like the one above.
Old 01-28-2017, 10:06 AM   #9
chevy2tom
chevy2tom's Avatar
This is a step notch the others are a "C" notch
chevy2tom is offline   Reply With Quote
Old 01-28-2017, 11:41 AM   #10
bjkttr
bjkttr's Avatar
That is what I am looking for a step notch. Did you buy your or just make it your self?
Old 01-28-2017, 11:51 AM   #11
chevy2tom
chevy2tom's Avatar
http://switchsuspension.com/chevrole...piece-c-notch/
Old 01-28-2017, 12:23 PM   #12
66tucknlugs
66tucknlugs's Avatar
Switch Suspension notch as well for mine.
Name:  step notch.jpg
66tucknlugs is offline   Reply With Quote
