Old 01-28-2017, 07:12 PM   #1
Isaiah92260
Isaiah92260's Avatar
Can't get the Horn to work right. HELP
I have a 63'. Got a Horn hardware repair kit for my delux steering wheel. When I plug in the pink horn ground wire from the steering bearing to the dark green wire on the steering column harness, the horn constant Honks, what the heck? Can't figure out why, please hlep
Isaiah92260 is offline   Reply With Quote
Old 01-28-2017, 08:46 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Can't get the Horn to work right. HELP
The horn button or plunger is grounded somewhere or may not be insulated properly. Which would be the same thing.
Old 01-29-2017, 01:47 PM   #3
Wrenchbender Ret
There is a flat metal spring under the horn ring. You need to remove the 3 screws & make sure the spring is centered under the plastic toobs.
Wrenchbender Ret is offline   Reply With Quote
Old 01-29-2017, 04:06 PM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I have also found that you don't want to over tighten the screws.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
