Old 01-31-2017, 12:21 PM   #1
blown240
blown240's Avatar
Can anyone ID this diff?
Im trying to see if this will work in my 61, but the owner isn't sure what it is...
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 01-31-2017, 12:25 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Can anyone ID this diff?
How many bolts in the cover and how many lugs dose it have? Looks like something that came out of 60 to 72 chevy truck depending on the Lugs. The pumpkin looks kind of small in that picture, but it could just be the angle.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-31-2017, 12:27 PM   #3
blown240
blown240's Avatar
Thats what I was thinking too. He is getting a measurement of how wide it is... i will ask about how many bolts on the cover.
Old 01-31-2017, 12:31 PM   #4
jayoldschool
Moderator
I have an idea... but just get him to turn it and take a pic of the back. We'll know immediately.
jayoldschool is offline   Reply With Quote
Old 01-31-2017, 12:56 PM   #5
scoot_mcgrute
Hard to say but it looks like a 10 bolt from an 80s pickup. A shot of the cover will help a bunch but the circled features point me to a 10 bolt.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 01-31-2017, 01:29 PM   #6
PGSigns
PGSigns's Avatar
Looks like one out of a 4wd. Almost looks like it has the bigger brakes on it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-31-2017, 01:31 PM   #7
blown240
blown240's Avatar
Here are some more pics. I have a feeling this is way newer than what Im looking for...
Also, I found another rear end thats out of a 66 GMC Suburban. The guy that has it says its not a 12 bolt though. What other options did the GMC Suburban have?
Old 01-31-2017, 01:39 PM   #8
scoot_mcgrute
That's definitely a 12 bolt
1966 Army Truck
Old 01-31-2017, 01:42 PM   #9
blown240
blown240's Avatar
I think it may be from an 80s truck, which would make it too wide for my 61...
Still wondering what the 66 GMC Suburban would have if its not a 12 bolt....
Old 01-31-2017, 02:02 PM   #10
61K10
61K10's Avatar
gmc dana 44
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-31-2017, 02:25 PM   #11
The Rocknrod
Moderator
The Rocknrod's Avatar
That's your basic 12-2 Alpha Delta Charlie right there. Basically.
Old 01-31-2017, 03:28 PM   #12
blown240
blown240's Avatar
What does 12-2 ADC mean?
Old 01-31-2017, 03:31 PM   #13
The Rocknrod
Moderator
The phrase is "your basic 12-2 Alpha Delta Charlie".
Whatever I want it to mean. In this case, I'm clueless as to what the rear end is.
Old 01-31-2017, 03:34 PM   #14
blown240
blown240's Avatar
LOL awesome. Ill have to remember that one...
Old 01-31-2017, 10:37 PM   #15
vince1
Does the 61 also have leaf springs? Spacing? What about U joint match up?
I have a 1970 (or 71?) 12 bolt in my 66 and like it that it is 1 1/2" wider than original.
vince1 is offline   Reply With Quote
Old 02-01-2017, 01:40 AM   #16
Captainfab
60-66 Nut
That differential IS a truck 12 bolt. It will be 1.5" wider than your original Eaton HO32/33. If it is 6 lug it will have been out of a 4x4.
A GMC will likely have a Dana 44 as already stated. Personally I would stay away from the Dana 44 as the brake drums are basically nonexistant and you have to modify other drums to make them work.
Old 02-01-2017, 01:07 PM   #17
blown240
blown240's Avatar
Thanks for the replies!!!
I found a local diff shop that will rebuild my stock rear and put 3.90 gears in it for $500. I am debating going this way. A newer 12 bolt would be nice, but between the price of the rear end and the work moving mounts and pan hard, maybe the $500 isn't too bad...
Old 02-01-2017, 01:40 PM   #18
61K10
61K10's Avatar
3.90 gears haven't been made for years. A set of nos ones on e-bay are $495 just for the ring and pinion. Have them put in 3.38"s as they are ave.
1961 chevy K10
Old 02-01-2017, 01:43 PM   #19
blown240
blown240's Avatar
he has 3 sets of 3.90 gears at the shop. He is throwing a set in for free basically with the rebuild. If I want 3.38, then I have to buy a set.
I have a 700r trans, so 3.90 should be fine...
Do you guys think I should just rebuild what I have for $500 and not worry about looking for a rear end?
Old 02-01-2017, 01:47 PM   #20
The Rocknrod
Moderator
Keep your stock rear housing and have it built.
Old 02-01-2017, 01:53 PM   #21
blown240
blown240's Avatar
The biggest downside of the stock rear end is not being able to get a Posi for it. But I guess don't really need one...
Old 02-01-2017, 06:27 PM   #22
scoot_mcgrute
I don't know about the earlier stuff but if you already have a 12 bolt, couldn't you swap the axle shafts out from a 65 or 66 to run a posi?
Is it more than a coarse vs fine spline difference on the 61 diffs?
1966 Army Truck
Old 02-01-2017, 06:47 PM   #23
blown240
blown240's Avatar
60-62 were Eaton rear ends. Not 12 bolts. I wish it was that easy....
Old 02-01-2017, 07:06 PM   #24
scoot_mcgrute
10-4, that makes sense.
1966 Army Truck
Old 02-02-2017, 02:28 PM   #25
61K10
61K10's Avatar
Go for it at that price. I looked for a set of 3.90 gears with no luck when i did mine. With your trans you should be fine with the 3.90's. these gears new nos?
1961 chevy K10
