Old 12-26-2016, 02:03 PM   #151
56hotrodred
Re: Putting Camaro front in 55 second gen
That all looks real good.
I hope to be there soon but still need to get second coat of frame paint completed.
Must be exciting to actually be building!
56hotrodred is offline   Reply With Quote
Old 01-07-2017, 08:43 PM   #152
Dave0
Thanks!
It runs! All plumbed up, even the steering. Spun it a couple times to build up oil pressure, primed the fuel pump 5 or 6 times, hit the ignition and fired instantly! No leaks anywhere, no hiccups! On to permanent wiring and the body!
Dave0 is offline   Reply With Quote
Old 01-08-2017, 10:26 AM   #153
Kim57
Kim57's Avatar
That's a nice point to be at.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-10-2017, 08:41 AM   #154
Dave0
Kim
Its nice to hear it run! I need a break though, I'll mess with the bed for a while....
Get rid of those destroyed ugly corners...
Old 01-14-2017, 07:59 PM   #155
Dave0
Before I weld the top of the bed sides shut, I decided to put some removable eyes for tie downs. I probably wont use them much so I made it so I can just leave them out....I put 2 in each corner, 8 total.
Also got the front panel and rear cross sill temporary bolted on, bedsides squared up.
Old 01-15-2017, 10:44 AM   #156
Oldtruckwelder
Oldtruckwelder's Avatar
Just went through your build thread.... nice work !!!!
I was very interested in your radiator core and bumper supports, that's where I'm at trying to get all the sheetmetal to line up. In the process of getting the bottom grill support to fit, I will have to notch front frame rail and lower bumper brackets to accomplish. Cutting the lower grill support would not be low enough on mine. Keep up the great build.
JT from SC
Oldtruckwelder is offline   Reply With Quote
Old 01-15-2017, 11:18 AM   #157
Kim57
Kim57's Avatar
Those eye bolts are a nice touch.
Kim
My build thread
Old 01-15-2017, 03:26 PM   #158
Dave0
Thanks guys!
I have both rears done, start on front then move to bed floor...
Old 01-15-2017, 09:40 PM   #159
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 01-16-2017, 10:22 AM   #160
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Very cool!
ChuckDriver is offline   Reply With Quote
Old 01-20-2017, 10:53 PM   #161
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
It's like lookin' at mine in a lot of those pictures. Same drive train and front suspension.
Rear is a little different
Nice project... lookin forward to seeing it finished...
Subscribed!
Ken
87Lowrider is offline   Reply With Quote
Old 01-25-2017, 09:33 PM   #162
Dave0
Thanks!
Front corners finished, one 77 inch patch complete! Trying to save as much old paint as possible...One more long patch and the bed is done!
Old 01-26-2017, 09:22 AM   #163
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 01-27-2017, 08:42 PM   #164
Dave0
Looks good.
Kim
Gona look like a rat rod! Lol
Playing with paint, this card was white an hour before I took these pics!
Old 02-01-2017, 04:58 PM   #165
Dave0
Planning bed floor and starting on cab...
Old 02-01-2017, 05:28 PM   #166
Kim57
Kim57's Avatar
That's one wild rotisserie.
Kim
My build thread
Old 02-01-2017, 08:00 PM   #167
ChuckDriver
Crazy!
Old 02-01-2017, 08:47 PM   #168
Oldtruckwelder
Looks like a used wire/pipe spool, what a great idea !!!!
JT from SC
Old 02-01-2017, 09:26 PM   #169
Dave0
I did! Fiber optic cable spool (free). Im going to put it on rollers tomorrow, so it spins in place...
I cut the top off, to 7 ft so I can get it out the garage door if needed. The top will bolt in place so it can spin 360
Old 02-04-2017, 01:19 AM   #170
tmoble
LOL, look at the stuff in the background of the last pic. I'd say Dave0 has been around some.
tmoble is offline   Reply With Quote
Old 02-04-2017, 11:17 AM   #171
MIKESAD50
What did you use for your transmission cooler and lines? where did you mount?
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 02-06-2017, 06:35 PM   #172
Dave0
I used a cooler off ebay with 6 an stubs already on it. I used 6 an russell braided lines and fittings. I will be mounted in the frame rail with a small fan on it. I will get pics as soon as I mount it.
All cut up and headed to be blasted!
Old 02-07-2017, 07:15 PM   #173
Dave0
Blasted! I spent a lot of time getting under the dash, inside hinge posts and cowl...The only big suprise was the rt front floor (last pic). Not a huge deal though...
Old 02-07-2017, 07:55 PM   #174
Dave0
Couple more
Old 02-10-2017, 09:26 PM   #175
Dave0
Taking a break from hard work! Made some wheels for the rotisserie... Finished off a bed corner and where the fuel filler was...
