#101 |
![]() ![]() Join Date: May 2015
Re: 1953 Extended Cab
Dang ..that things looking like a truck again..what size tires you running?
#102 |
Them there are some nice steam rollers!! If I see it right, 335/30/20?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#103 |
Great, that should take some abuse !
#104 |
Sexy from rear! Love that wheel and tire combo.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and 47RH AOD transmission http://67-72chevytrucks.com/vboard/s...d.php?t=640042 |
#105 |
![]() Join Date: Apr 2005
Awesome build!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#106 |
following!!!!!!
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks ![]() |
#107 |
Thanks everyone. 335/30/20 tires
http://67-72chevytrucks.com/vboard/s...d.php?t=648783 |
#108 |
![]() Join Date: Mar 2007
Love everything about your truck especially the wheel and tire combo. This is the same diameter tire that I run on my 48 (only wider). Nice too see a 20" wheel with some decent sidewall.
Thanks Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#109 |
Ok got the size..now what brand tire you got?
#110 |
michelin pilot super sport
#111 |
Fronts are on now
#112 |
Looking good on all 4s
#113 |
Could you tell me what you used for the skin on the roof? I'm considering the Sam stretch for mine and I was thinking of using the skin from the back of the cab to match the rounded edge. I would be dering the cab back panel from LMC.
#114 |
Another question, how long did you stretch the cab? This is a great build. Thanks for sharing.
#115 |
I did a stretch on a 53 and found out when finished if we would have gone only nine inches we could have used the running boards from a long bed and saved a bit of time on extending the boards, just my $.02
#116 | |
Posted via Mobile Device |
#117 |
Thanks for the info. I'm new to the custom truck build world. I've had my truck 22 years since I was 15. I've tried starting the build several times, this time I want to see it through and get her on the road... it's about time.
#118 |
Yeah that sounds good but where can I find a suburban roof?
#119 |
I never looked for that particular item but my parts came from fixmyrust.com
#120 |
Bought a 2000 Chevy Truck for the drivetrain to use in a 31 Chevy I'm doing. Added bonus , I am using the seats in the 53.
Test fitting the rear seat. Not bad, going to modify the mounts and lower it a bit. Probably get rid of the headrests. It fits but tight. Think I am going to ditch the center jump seat and just build a console. The girls have claimed the truck.
#121 |
Sweet, the truck is looking good. Do you think you added enough space for the back seat? You said that you added around 20"?
#122 |
After I modify the back seat to fit like I want it, it will be similar to the room in a modern extended cab. That being said, I am spoiled by my daily driver (2013 F-150 Crew Cab) which has as much room in the back as in the front. This will work ok for me but 4 more inches would have been nice (I've heard that somewhere before).
#123 |
Yes, ditch the head rests and that seat looks very good in there..
I like the idea of lowering the seats slightly as well. Marc
#124 |
Those seats are going to make the truck so nice to drive.
#125 |
Starting to layout wiring for the truck. I won't actually make any connections yet. This is so I can make any needed holes, mounts, plates, etc before paint.
Tags |
#projectmater, 5 window, art morrison, extended cab, ls engine |
