Old 02-07-2017, 02:10 AM   #1
sokudo7
LQ4 in to 68
trying to round up all the parts I will need to do the swap. any suggestions/recommendations will be muchly appreciated.
not trying to do things the cheapest way, but not trying to break the bank. just a solid, quality build.
I am defiantly wanted to run long tube headers. which one offer the best ground clearance?
how is the BRP mount kit work with there headers?
is the LH8 oil pan give that much more clearance?
is there a direct fit LS swap radiator out there some where?
sokudo7 is offline   Reply With Quote
Old 02-07-2017, 10:48 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: LQ4 in to 68
This is what I used: Dirty Dingo slider mounts and CPP engine stands, Cadillac CTSv oil pan, Entropy radiator and Doug Thorley 324 Try-Y headers. You can check out my builds in signature.
I would also look through these threads, they will be a good place to start and lots of good information:
http://67-72chevytrucks.com/vboard/s...d.php?t=566743
http://67-72chevytrucks.com/vboard/s...d.php?t=456787
If you do a DBW pedal, I also make an adapter bracket for mounting the pedals in a C10:
http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Good luck on your swap!
I used Dirty Dingo slider mounts and CPP engine stands, Cadillac CTSv oil pan, Entropy radiator and Doug Thorley 324 Try-Y headers.
Hart_Rod is offline   Reply With Quote
Old 02-07-2017, 01:31 PM   #3
binford
Re: LQ4 in to 68
I started here
http://67-72chevytrucks.com/vboard/showthread.php?t=413855
I have not set the motor yet. I want to see how the A/C compressor fits.
My plan is move the stock mounting stands back so the compressor will fit.
binford is offline   Reply With Quote
Old 02-09-2017, 02:46 AM   #4
sokudo7
Re: LQ4 in to 68
Doug Thorley says those wont work with stock column shift. don't really want to go to floor shifter. trying to get more info on the BRP stuff. anybody used them?
