Old 02-08-2017, 11:11 PM   #1
Garagely5150
Pinion angle on tranz
Anyone know how I can squeeze a couple more degrees of pinion angle on my tranz.. I have a gen 1 pb drop xmember and my pinion angle right now is 7* I was under the impression that as long as the pinion angle on the rear and was 180 opposite I'd be in good shape. But now after talking to expirienced builders I learned it should be 3* .... but I can't jack up my tranz with out putting stress on my motor mounts 7* was the most I could get out of it with out having the bushing squished on the motor mount. And just to get it at 7* I had to shave my steering rack down bc it was hitting my oil pan. And I had to roll the edge of my oil pan too. Any one ever hear of this? It's pb I wouldn't think I'd have this problem.
Garagely5150 is offline   Reply With Quote
Old 02-08-2017, 11:19 PM   #2
andyh1956
Re: Pinion angle on tranz
Your COMBINED crank / trans angle PLUS the PINION angle DIVIDED by TWO should be under 3 degrees for optimum performance.
Example- if the trans is 4 deg & pinion is 3 deg then 4 + 3 = 7 / 2 = 3.5 degrees.
andyh1956 is offline   Reply With Quote
Old 02-08-2017, 11:40 PM   #3
Garagely5150
Just a pic to go along with the post
Old 02-09-2017, 07:43 AM   #4
Keith Seymore
Keith Seymore's Avatar
Do you have the chassis set to the intended ride height?
These angles need to be measured as though it is a fully assembled vehicle with the full weight on the wheels. That could potentially "raise" the rear axle relative to the frame and flatten your driveshaft/trans tailshaft working angle out.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-09-2017, 08:21 AM   #5
Garagely5150
Yea it's set up at ride height. Frame is level....
Old 02-09-2017, 11:34 AM   #6
SCOTI
SCOTI's Avatar
I have an early ('07?) PBDM in my 64 (68 frame) & didn't have issues w/binding @ the motor mounts. PB recommended 5° @ the trans output shaft but I made a spacer to put mine closer to the traditional 3° angle. No interference up front either w/the R&P & motor (sbc w/a 700r4). Your set-up has me scratching my head. Any more details you can provide?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-09-2017, 08:18 PM   #7
Garagely5150
I bought the whole assy used I'm not 100% sure the motor mounts are the right ones bc my engine is on a wicked slant. I wish I had more for u... u have to Chang ur oil pan buy any chance ?
Old 02-10-2017, 02:38 AM   #8
SCOTI
SCOTI's Avatar
Stock stamped steel 5qt pan.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-10-2017, 11:14 AM   #9
Garagely5150
Pb recommends 5* tho huh I wonder if that goes for mine too? I was talking to pb about this problem via email but they left me hanging
Old 02-10-2017, 11:15 AM   #10
Garagely5150
I thought about heating the motor mounts up with the torch and jacking up the tranz. Or possibly pie cut them
Old 02-10-2017, 02:26 PM   #11
tinydb84
tinydb84's Avatar
Do you have better pictures of all the interference points? Granted I cant really see what you are working with but I would look at redoing the bottom tabs where the motor mount attaches to the cross member.
You could cut new tabs and raise the engine just enough to clear the rack at the same time as correcting the trans angle.
David
Instagram: myfabguy
Old 02-10-2017, 03:48 PM   #12
SCOTI
SCOTI's Avatar
He does recommend the 5° set-up angle. I talked w/him @ length about this.
Porterbuilt might be more eloquent w/his explanation but here's my summary.... Extreme drops come w/the caveat of compromise. His standard method is the 5° angle & a 2pc driveline. Given that usually works well for most apps, I chose a different path but needed to better understand the 'Why' in his recommendation. I felt that going through the expense of a 2pc driveline & it still possibly being a greater than desired compromise would be a roll of the dice (I experienced this 1st hand in someone's truck). The fix? Adding in a Double Cardan/CV joint.
I opted to do 3° & a 1pc driveline as it's more common w/hot-rod builds & is a standard. I could save money using the 1pc & avoid the added complexity. If there's an issue w/vibration, I can still swap to that same Double Cardan/CV joint. To me, the cost difference & 'dumbing things down' was worth cutting up some of the bottom of my cab.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-11-2017, 12:29 AM   #13
Garagely5150
What's a cardon cv joint and it requires cutting up the cab? Drive line = drive shaft ?
Old 02-11-2017, 01:17 AM   #14
SCOTI
SCOTI's Avatar
Yes.... Driveline = motor/trans/driveshaft to pinion.
Double Cardan/CV joints are popular w/trucks that have serious lift. Google them.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-11-2017, 02:25 AM   #15
wilkin250r
wilkin250r's Avatar
A double-cardan joint (also called a CV joint) can handle more angle than a universal joint, BUT operates a little different. With a double-cardan, you align the axle pinion directly inline with the driveline, you do NOT match the transmission angle.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 02-11-2017, 05:25 PM   #16
El Dorado Jim
x2
El Dorado Jim is offline   Reply With Quote
Old 02-13-2017, 11:38 PM   #17
andyh1956
This is what we went with on our K5 Blazer w/ 4" lift. NO vibes!
Old 02-14-2017, 12:20 AM   #18
Garagely5150
I don't don't know about doing a cv joint I just wanna get my tranz angle to 3*
Old 02-14-2017, 01:48 AM   #19
SCOTI
SCOTI's Avatar
How low are you going? You may need to know & understand the parts. I never had issues w/my other trucks (other than the differential hitting the bed floor) & that was w/stock frame. Add a different/aftermarket front xmember + other alterations and especially if you run an OD trans..... it could be very necessary.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-14-2017, 10:52 PM   #20
Garagely5150
It's gonna lay frame
Old 02-17-2017, 02:32 PM   #21
Garagely5150
What goes into changing to cv joint style drive shaft. What does it cost
Old 02-17-2017, 04:10 PM   #22
SCOTI
SCOTI's Avatar
A CV joint set-up was about $150 last time I checked (2013?) when I had my 1pc shaft built. I had my 1pc shaft built by cutting down a longer unit & then balanced for ~ $125.
When I priced a balanced 2pc set-up w/a poly/billet carrier bearing @ the same place it was about $650 (that was w/everything new as I never had any C10's w/a 2pc set-up to have used parts as my starting point).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
