Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-10-2017, 06:54 PM   #1626
knomadd
knomadd's Avatar
Re: 1969 SuperBurb build-up (Bagged and Blown!)
I say white. It looks clean, brightens it up, ties in with the white in the hounds-tooth pattern and the white on the exterior. Just don't touch it! Black would work, but I tend to agree with the others, it might be too dark inside. Either way, I think it will turn out nice.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-11-2017, 03:01 PM   #1627
72MARIO
72MARIO's Avatar
I like the white in my suburban. I wouldn't change it to black. The white keeps it bright at night.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-11-2017, 04:39 PM   #1628
3drburb
I guess I will be the Lone Ranger on this one without Tonto.
Quick points on the black.
So I am guessing this will be more of a show truck than driver as far as darkness goes and that what interior lights is for, on top of the fact that these Burbs are glass houses on the road so the black would be better especially with the other bright and funny looking blue headlights from other cars shining in there if you do drive at night.
As far as coffin feeling the red window post pretty much break up the black, now if the headliner was to match the seat inserts then yes that white.
This ride has a lot of white already and although it will look good white, I don't think the white would look uniform and finished off as the black.
Man you probably shouldn't have asked us, this is a tough one and honestly anyway you go on this it would be nice.
3drburb is offline   Reply With Quote
Old 02-13-2017, 09:25 AM   #1629
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 04ls1gto View Post
The white looks clean
Originally Posted by boostedc10 View Post
I second the white.
Originally Posted by VA72C10 View Post
The black would make it pretty dark in the interior.... I like the white
I am for the black, mostly because anything white on an interrior for me ends up black not to long after the install.
Originally Posted by AnotherWs6 View Post
I would have gone white with everything, but DEFINITELY would keep the headliner white. Would look like a coffin in there with your bright, jazzy paint job outside. Doesn't make sense. Keep it bright with contrast.
Originally Posted by 3drburb View Post
The white looks good but the black will look a lot more finished with everything else.
The white will clash with the seat inserts being that it appears much brighter than them.
So I will vote for black.
Originally Posted by kehstr View Post
This is exactly what I see being the problem, other than black I think will make the interior too dark. Is there a way that you can make some design using both colors?
I appreciate everyone's input! Here's what I decided to do. I'm going to go with white and if it ends up being to bright I will try to figure out a way to paint it black or cover it. I looked at Lowes for the FRP and I found 2 different colors of white. One was a really bright white and shiny and the other one was kinda an egg-shell color and satin. I'm going to use the egg-shell/satin one. I think it looks pretty close to the stock color of the factory headliner (could be wrong ) I've attached pictures of both, but I don't know if you will be able to tell the difference (first one is satin, second one is shiny). Also, I finished all of my FatMat so I threw the carpet in just to see how everything looks.
Hart_Rod is offline   Reply With Quote
Old 02-13-2017, 01:48 PM   #1630
Hart_Rod
Hart_Rod's Avatar
Here's a couple more carpet pictures.
Old 02-13-2017, 01:56 PM   #1631
boostedc10
boostedc10's Avatar
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 02-13-2017, 02:38 PM   #1632
nastety92
Carpet looks great Rob. What color gray is that? Also what finish carpet did you go with?
nastety92 is offline   Reply With Quote
Old 02-13-2017, 02:58 PM   #1633
Hart_Rod
Hart_Rod's Avatar
Thanks!
Charcoal black, Essex die cut.
Old 02-14-2017, 11:39 AM   #1634
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Rob,
I think you made a good choice on the headliner, I was thinking of the same for mine. You should be feeling good as you get that much closer to a finished product!
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 02-19-2017, 10:40 AM   #1635
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Twisted78SS View Post
Rob,
Thanks! I got the rear panel done yesterday. I'm debating on whether or not I want to combine the 2 small center panels into one. In theory, it seems like it would make the installation easier. Here's a couple of crappy pictures. Will try to take some better ones today or tomorrow. Here's the threads I have been using to help with the headliner build and installation:
http://67-72chevytrucks.com/vboard/s...d.php?t=410459
http://67-72chevytrucks.com/vboard/s...ight=headliner
Also, a big thanks to boardmember Portheadlight for sending me templates for he front and rear headliner panels.
Old 02-23-2017, 02:25 PM   #1636
Hart_Rod
Hart_Rod's Avatar
Front headliner piece
Old 02-25-2017, 07:32 PM   #1637
Frizzle Fry
Frizzle Fry's Avatar
Lookin good Rob!
Frizzle Fry is offline   Reply With Quote
Old 02-25-2017, 10:14 PM   #1638
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Frizzle Fry View Post
Lookin good Rob!
Thanks Mike! Hope all is well with you and your family.
Old 02-27-2017, 09:02 AM   #1639
Hart_Rod
Hart_Rod's Avatar
Hung some sheet metal this weekend...
Old 02-27-2017, 09:03 AM   #1640
nastety92
Wow the truck looks great Rob. Have you thought about painting the middle of the grill black?
Old 02-27-2017, 09:07 AM   #1641
Hart_Rod
Hart_Rod's Avatar
Thanks! Honestly, I really like the factory look of the silver.
Old 02-27-2017, 09:22 AM   #1642
likaroc13
Rollin' Old Skool
Glad to see it on the home stretch Rob! Good choice (IMO) on the white headliner.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 02-27-2017, 12:37 PM   #1643
smbrouss70
smbrouss70's Avatar
Looks great Rob! When does the custom trim go on?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-27-2017, 01:53 PM   #1644
Hart_Rod
Hart_Rod's Avatar
Thanks! The list is getting smaller, .
Thanks! The trim will probably be the last thing I tackle.
Old 02-27-2017, 07:51 PM   #1645
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Man that looks awesome!
ChuckDriver is offline   Reply With Quote
Old 02-28-2017, 12:53 AM   #1646
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That looks great! I like the new emblem. Who did you have make it?
Ryan
1969 Chevy milk truck
Old 02-28-2017, 09:52 AM   #1647
Hart_Rod
Hart_Rod's Avatar
Thanks!
Thanks! Boardmember Shortie made the emblems. He's making all kinds of custom emblems.
http://67-72chevytrucks.com/vboard/s...d.php?t=701118
Old 02-28-2017, 09:33 PM   #1648
NC_John
NC_John's Avatar
Sub'd because I LOVE this truck!
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 03-01-2017, 05:49 PM   #1649
Dieselwrencher
I should have known.
Ryan
Old 03-06-2017, 11:31 AM   #1650
Hart_Rod
Hart_Rod's Avatar
Thanks John!
Still tweaking the front sheet metal, but we did get the grill and bumper installed. Lots of work to make it fit and look right, but well worth it in the end.
