292 to 327 swap
I am pulling the 292 out of my 66 and want to install a 327, with a Saginaw automotive 4 speed. What do I need for motor mounts, can I move one side of my mounts? Will the clutch setup work OK? Thanks, taclem
Re: 292 to 327 swap
Your passenger side motor mount will need to be changed, the drivers side should work fine as well as your Bellhousing, but I'm not 100% sure on the clutch
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
Re: 292 to 327 swap
Everything for the clutch should still work, I just swapped a 230 for a 327.
Re: 292 to 327 swap
you will need the passenger side frame perch from a 230, 250 i6 or a 283 63-66. for the clutch linkage you will need the threaded ball stud engine side for a sbc. yje i6 uses a pressed in ball stud on a bracket/ you cannot use that one
http://www.persh.org/pickup/perches.htm ron |
