Old 06-27-2001, 10:58 PM   #1
Brad
Out of the carpool lane.
Brad's Avatar
Post weird susp. prob
I recently conv. to 77 disk using the 67 crossmember and 77 spindles, a-arms, etc. This past weekend I cut the coils some more hoping to cure my prob but still have it. It is this: the coil is seated correctly, yet is rubbing inside the pocket on the crossmember. It is sitting somewhat at an angle on both sides. I cut both equally; I seated pigtail side correctly-also the cut end in pocket dip. This is annoying-help!
have close to 5" drop if this helps.
68 Camaro,250(No,I'm not putting in a 350!)
67,LWB,250(Again, I'm not putting in a 350!)
a work in progress
"Praise The Lowered"
Bend, Or (for the summer)
[This message has been edited by Brad (edited 06-27-2001).]
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 06-28-2001, 09:00 PM   #2
cdwhzk
Post
If I'm reading your post right you cut 5inche off the springs?? if so that's probably your problem there's a reason why the reputable manufactures only sell 3inch max drop springs!!! cutting springs to lower a vehicle is not a good idea!!! get lowered springs and spindles in combination if you want to lower your truck safely and still have a good riding suspension
71c10 350/350 air ps pb 320hp crate 2004R tranny from FB performance 410moroso posi completely rustfree body
27T coupe chopper 6.5 inches channeled total height 41inches powered by bigblock Edsel punched out to 490ci topped with 6stromberg97's built back in 67
Whizzer motorbikes 6or7
71C5 Blazer 350/350 needs rust repair but runs new
74Pinto stationwagon daily driver
cdwhzk is offline   Reply With Quote
Old 06-28-2001, 09:37 PM   #3
Brad
Brad's Avatar
Post
Nope, I've got 2" drop spindles. About a 5" drop overall. I used 77 springs (very soft in 25 years) and cut approx. 3" over several times (had 3" then 4" now 5"). The ride itself is great-not stiff at all (again I used 25 yr soft springs!) But, a portion of the spring still rubs in the cup of crossmember. I tried to fix by cutting more and seating it differently each time but to no avail. I don't buy new drop springs 'cause I suspect they'll do it too! I wonder if it's the crossmember. Has anyone experienced this prob before?
a work in progress
Old 06-29-2001, 04:28 PM   #4
69Custom
69Custom's Avatar
Post
I removed cut spring from my 83. I have drop spindles, and the spring where cut by the previous owner. One spring was weaker than the other. The truck was leaning. So I replace the springs with ones that were not cut. As for them rubbing, I could only say do you have the spring end toward the inside of the truck where the groove starts. I put them in by undoing the back of the control arm and not by removing the spindle, so that I can make sure that it is going in straight.
I would take lowering springs over cut springs anyday. They are more stable, cut spring become weak when cut and are unstable. Just my 2 cents.
  • 72 Blazer 4WD 307/3 spd, PS, PB, Posi (for sale)
  • 72 c5 Blazer CST (In process of aquiring)
  • 83 Chevy SWB Rebuit 350/TH-350 with shift kit, buckets (daily driver)
http://members.nbci.com/luc_nt/index.htm
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
Old 06-29-2001, 09:51 PM   #5
Brad
Brad's Avatar
Post
Ya, I've got the cut end in the end of groove on lower arm. One spring leans forward, one rearward(because the springs aren't symetrical.) I may try like you said and install from u-bolt side. Thanks
a work in progress
Old 07-05-2001, 05:32 PM   #6
69Custom
69Custom's Avatar
Post
Brad, Did you have any luck with your suspension problem. Just wondering if you were able to fix it or not. Also if your spring is not symetrical I would not use it. All of the ones that I have seen even in the junk yards are symentrical. It sounds like those springs have had it. Maybe time for some new ones.
[This message has been edited by 69Custom (edited 07-05-2001).]
(Current Project)
2002 Saturn L200
Old 07-05-2001, 09:32 PM   #7
Brad
Brad's Avatar
Post
I haven't had a chance to tweak them. BTW, when I say symetrical, I mean springs are only coiled one way--clockwise or c-clockwise--I forgot, and lean accordingly sitting in the a-arm pocket after having been cut. If things are done right (emphasize done right!) cut springs or heated springs are safe. I've done both with success several times. However, I'm looking into buying 3-4" drop springs.
a work in progress
Old 08-09-2001, 11:48 PM   #8
Brad
Brad's Avatar
Lightbulb
Update: I bought new 3" drop springs, installed them and no more problem. Turns out the old springs were leaning like this: ( and ). The new springs are heavier gauge making them stiffer yet softer. No more rubbing.
a work in progress
Old 08-10-2001, 02:26 AM   #9
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Exclamation
yeap cut springs SUCK
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
