evaporust is the best
I have been using this stuff for a while on small screws and hardware. I am currently removing rust from my interior heater box. I broke down and bought a gallon of it so I could get rid of the light surface rust I can't reach with a wire brush. Can you tell how high the bath went? Wow.
Re: evaporust is the best
Yep, my 3.5 gallon is in route to me! Works great.
![]() Join Date: Aug 2004
Thanks for the reminder, I'll be needing some soon. Lots of rusty old crap to clean up. It works amazingly well.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
![]() Join Date: Feb 2009
That looks real good. Ever try white vinegar? It turns rust black then comes off with a brush. The Evaporust may be better for heavier rust.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Mar 2010
My 80 year old uncle thought i was pulling his chain about the vinegar trick. But at a fraction of the cost you get nearly the same results. He had about 100 clamps that were rusted up. A good soak in vinegar overnight and they were almost like new again. I do like the Evaporust products but cant spend the money when i know there is an alternative. Come to think of it i think i learned about the vinegar trick on this forum!
1969 Chevy K20 Longbed |
#6 | |
![]() Join Date: Mar 2011
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
If you don't mind the looks of galvanized metal, try this: http://bit.ly/2lGoS36.
You can also buy "blueing" solution from gun builder suppliers. The metal turns a bluish black, and is pretty rust-resistant. |
#8 | |
