02-14-2017, 02:42 PM | #1 |
Ring and pinion choice for 4.8 LS
My 72 currently has a spool rear end and I'm going to have it changed over to most likely a posi or maybe an open. I was wondering what gear would be best for my setup. Will be a once in a while cruiser to work and to shows.
The engine is a 2007 4.8 LS with a 4l60e trans, controlled by a Mega Squirts MS3 Pro controller. The rear tires will be 28.66 in diameter. I'm not sure what the overdrive ratio is for a 4l60e trans. Can anyone help me with the formula for figuring this out? I was thinking on going with a 3:55 or 3:73. Thanks
1972 C10 Custom Deluxe 4.8 LS 4l60e |
02-14-2017, 02:50 PM | #2 |
Re: Ring and pinion choice for 4.8 LS
Oh and the motor is a stock 4.8, the trans has a stock stall. Might possibly update that in the near future. May also add a single turbo set up.
02-14-2017, 04:01 PM | #3 |
Im not sure you can get a 3.55 rear gear for these but I note recently looked. For your combo I would go with the 3.73 that is what I had for years. The over drive in the 4l60 is .70.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-14-2017, 04:03 PM | #4 |
I have tried to include a zipped file that has a spreadsheet inside it. This can be used to calculate the speeds and other info based off tire size, gear ratio and transmission.
Good luck Dave
02-14-2017, 04:19 PM | #5 |
Thanks Dave!
02-14-2017, 07:39 PM | #6 |
I would second the 3.73. I have driven many ls powered trucks with various displacements with 3.55, 3.73, and 4.10. The 3.73 seems to be the perfect harmony of cruising speed and excellent response.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
02-14-2017, 08:41 PM | #7 |
3.42 or 3.73 are your options in that range, there is no 3.55. I just bought a ring and pinion for mine. You can get a 3.55 for car 12 bolts, but not the truck 12 bolt, this is atleast what I found.
I went with a 3.73 for more get up and go over the 3.42. I guess in my case the small amount of mileage gain wasnt worth it for me on a fun weekend cruiser, I want this thing to move quickly. |
02-14-2017, 09:07 PM | #8 |
I have the 4.8/4l60e with 28+" tires, went with the 3.73 rear gears and still get 19-20mpg on the highway.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 02-15-2017 at 08:48 PM. |
02-14-2017, 11:01 PM | #9 |
I have 3:42 with 28" 6.0/4L80 It needs 3:73 for my driving preference
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-15-2017, 07:25 AM | #10 |
I am against the 3.73 in light of your single turbo goals. 3.42 will still be peppy behind the 4l60e. Stock truck ecm really comes to life with a basic tune. Tuned by Frost did my C10 a few years back. Made quite the difference, despite the 2.73's and long 1st gear in the 4l80e. I am going twin turbo on mine so a 3.4# something gear is what I plan to install after.
Science flies you to the moon; Religion flies you into buildings. LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/ |
02-15-2017, 12:54 PM | #11 | |
02-19-2017, 04:52 PM | #12 |
Senior Moment
I'm running a 5.7 with a T56 six speed, Ford 9' with 350 gears. At 80 mph I'm only tacking 1740 rpm. I'm thinking at least 3;73 range if not 4;11 in the near future.
1st - 4th pull very strong 5 & 6 Freeway only. A LOT of FUN to drive
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
02-19-2017, 06:35 PM | #13 |
I have 4.8 with 4l60e in my 69. Currently 3.08 gears with 255/60/15. Freeway driving is great. In the foot hills where I drive is kinda lugs around. I find myself having to push more on the throttle to get out of over drive or I just down shift out of overdrive. I noticed after switching from billet wheels to the truck steel rallies this was more prominent. I do miss my billet wheels just base on the rolling mass difference.
02-20-2017, 11:06 AM | #14 | |
Now I am at a 4l80 and not liking the 4.11 so much lol and may eventually swap back to the 3.73. I would like your 3.50 but in my 12 bolt it is not much option...
