vintage air SBC to LS ??
anybody already have a Vintage air system installed on a small block and then decided to go LS? I'm kicking the idea around about an ls1/6 and dont know what will be involved with the engine swap concerning the Vintage air I've already got.
Re: vintage air SBC to LS ??
Shouldn't be a problem unless you try and run a "stock variable speed compressor". Call Vintage air. They have really knowledgeable guys who love to talk AC systems. Really helpful I have found.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
The challenges as I see them:
Nothing in the cab should need to change -- bracketing and mounting of accessories -- compressor, may or may not mount to an LS -- if it can be mounted, no issue, otherwise maybe new compressor routing of lines/hoses -- if you keep everything in the same location under the hood, no issue -- if compressor swaps sides, routing of the lines/hoses would be issue -- if condenser,dryer has to be moved, same thing -- for the heater, I figure some new hose would do it. Clearance -- the LS may or may not allow your current equipment to stay as-is Otherwise, the VA system doesn't really care what motor you're running. That is, unless you also purchased the Front Runner system! Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
