02-14-2017, 11:23 PM | #1 |
62 GMC 3/4 Ton Flatbed
Picked up this 62 gmc on Saturday. 97,000 miles with original v6. Was told it ran a few years ago but the radiator is missing.
Went to a new home in January 2018.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more Last edited by Classic v6 GMC's; 03-19-2018 at 03:29 PM. |
02-14-2017, 11:29 PM | #2 |
Re: 62 GMC 3/4 Ton Flatbed
Decided the bed would look better on the 67 c20 so we spent Saturday and Sunday swapping the beds.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
02-14-2017, 11:38 PM | #3 |
Pics after it was washed, new bed, single rear wheels, gmc grill and hood.
02-14-2017, 11:41 PM | #4 |
Pics
02-14-2017, 11:46 PM | #5 |
Pics 2
02-14-2017, 11:50 PM | #6 |
Cleaned out the cab.
02-15-2017, 12:05 AM | #7 |
Subbed! Can't wait to see it run, plans?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-15-2017, 12:21 AM | #8 |
I can't either. Going to do some small things to get it back on the road.
Will post some more pics tomorrow.
02-16-2017, 11:41 AM | #9 |
Pulled the old seat and gas tank out and installed a new gas tank.
Then we had a nice seat that we needed to use in something and it matched the arm rests. One of the few options the truck has is the limited slip rear axle.
02-16-2017, 11:46 AM | #10 |
Pulled the carb off and installed a rebuilt one.
Installed new battery cables. Installed a radiator and just waiting for new radiator hoses.
02-16-2017, 11:56 AM | #11 |
Getting excited! Hope you are able to get some videos!
02-16-2017, 11:50 PM | #12 |
I will try and take a video when we get it running.
Today I filled up the master cylinder up and tried to get the brakes and clutch working. The clutch pumped up but the brake side is leaking. Going to get a repair kit and gas tank sender on Saturday.
02-18-2017, 11:21 PM | #13 |
Pulled the master cylinder and decided that we might as well get a new one.
Went to classic parts and picked one up. Got it installed and the clutch works and we have brakes on 3 corners. Also picked up a new gas tank sender and got it installed. Still waiting for the lower radiator hose.
02-18-2017, 11:35 PM | #14 |
Looking good! Hopefully it fires right up!!
02-19-2017, 01:45 AM | #15 |
Nice truck and nice work, can't wait to here the big six rumble
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
02-19-2017, 11:52 AM | #16 |
One foot in front of the other
Nice
02-24-2017, 11:33 AM | #17 | |
02-24-2017, 11:37 AM | #18 |
Finally got the lower radiator hose.
Hope to get it running this weekend.
02-24-2017, 12:43 PM | #19 |
Whoohooo! Excited! lol
02-24-2017, 02:16 PM | #20 |
Wow that is in nice shape! I hope you get it going soon!
03-05-2017, 09:13 PM | #21 |
Well we got some time today and got it running. We pulled the distributor cap and to our surprise the cap is like new and someone has installed a Pertronix Ignitor!! Then pulled the spark plugs and they looked good so we poured a little gas down the carb and started cranking it over and it fired right up. With a little carb adjustment it is running good.
Link to video https://drive.google.com/file/d/0BwJ...ew?usp=sharing
03-06-2017, 12:48 AM | #22 |
Sweeet!
Sounds good! Seems to have the same exhaust leak mine did!
03-06-2017, 12:16 PM | #23 |
Thanks. It need exhaust work for sure.
03-07-2017, 12:42 PM | #24 |
Installed new brake hoses on the front and know we have brakes on all 4 corners.
Went to install the new rear hose and it is to short. I looked at the rear end and it still has the limited slip and 4:10 gear tags. Also set a air cleaner on it. Need to get a filter.
