Old 02-15-2017, 07:24 PM   #1
FNBasham
Bought a 4wd frame what are the differences
Bought a frame for a 1974 c10 that is 4wd what are the frame differences between that and a 2wd truck I have a longbed Donor truck can I convert this frame to 2wd?
FNBasham is offline   Reply With Quote
Old 02-15-2017, 09:59 PM   #2
cdub2010
Re: Bought a 4wd frame what are the differences
http://www.chuckschevytruckpages.com/framespecs.html
cdub2010 is offline   Reply With Quote
Old 02-15-2017, 11:09 PM   #3
UKNOWME
UKNOWME's Avatar
I've know a handful of people to strip the frame down and convert to 2wd with no issues. Looks like the link above proves it's pretty much the same frame.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 02-16-2017, 01:25 AM   #4
FNBasham
So what has to be stripped and moved exactly?
Old 02-16-2017, 07:56 AM   #5
andrewmp6
The front end is a lot of work.basicly the front needs to be stripped down to the frame rails even the steering boxes are different.The rear i think its different springs or shorter not 100% sure on that.
Old 02-16-2017, 10:50 AM   #6
UKNOWME
UKNOWME's Avatar
Yeah basically all steering and suspension
1964 Chevy c10
Old 02-16-2017, 11:11 AM   #7
FNBasham
But if I have the 2wd to take parts from I'd just need to drill a few holes?
Old 02-16-2017, 05:36 PM   #8
1968vetL-71
Junior Member
1968vetL-71's Avatar
I agree with andrewmp6.... That's a lot to do. 2wd frames are usually plentiful. Why go through all the work??
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 02-16-2017, 05:45 PM   #9
UKNOWME
UKNOWME's Avatar
Cut some rivets and drill away! It'll be something to be proud of
1964 Chevy c10
Old 02-16-2017, 05:49 PM   #10
FNBasham
I can't seem to find one
Old 02-16-2017, 09:46 PM   #11
franken
Another issue is there's a reason things are riveted to the frame, not to mention 4x4 frames are relatively rare since what 10% od trucks are 4x4?
The rivets fit the holes w/ no clearance and are actually a pain to remove. Bolts will fit loosely and will have threads in contact w/ the frame and bracket. Thus, when moving, the truck will flex that bracket/frame/bolt and try to loosen the nut, break the bolt, and make the hole bigger. Nothing will stop the process other than not driving. Do you want your suspension attached to the frame by bolts?
Old 02-16-2017, 09:58 PM   #12
FNBasham
Well if anybody know a person who wants a 4wd frame I'll trade it for a 2wd or just sell it outright for a good price
Old 02-16-2017, 10:23 PM   #13
UKNOWME
UKNOWME's Avatar
What were you plans with the truck? You might also consider shortening the longbed frame. There are many write ups on that.
1964 Chevy c10
Old 02-16-2017, 11:04 PM   #14
FNBasham
I'm thinking about doing that but now I have to off load this frame
Old 02-17-2017, 12:26 AM   #15
jbristo67
resident oilfield trash
jbristo67's Avatar
Ummmmmmm I've put over 100k on a truck with bolted on leaf spring hangers. It's not a big deal.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-17-2017, 08:00 PM   #16
Tom
driving is in my blood
Tom's Avatar
I have no problems using bolts for pretty much anything other then putting aircraft skin together.
Old 02-17-2017, 11:39 PM   #17
Jeff's bowtie's
I've also used bolts on many spring hangers and had no problem but I also drilled the rivet holes out to a 1/2" and use grade 8 bolts & nuts
Jeff's bowtie's is offline   Reply With Quote
