Spank 'em if you got 'em!
Anyone built a sandblast cabinet?
I am looking for suggestions or recommendations. I want to build a pretty good sized one, but I would like to hear from some folks who have them to get some ideas of what I need to take into consideration.
Thanks, Ro
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
I built one using 3/4 inch plywood and a kit from www.tptools.com . It is 4ft by 3 ft by 3 ft (approx)
I have to take off right now, but i'll try to post again tomorow with more info.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
blast cab.
![]() ![]() ![]() ![]() ![]() Kaukauna WI Airplaines don't land here they are sucked down |
emmett, good link
I've got one from Harbor Freight.....the light didn't last long in it and having a hard time seeing inside the thing after a few minutes of use....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Self-proclaimed LED man
Dad and i made one out of plywood. instead of using a siphon fed one inside the box, we used his portable sandblaster. It works pretty good. We used a vaccuum from the carwash to suck the dust out. I will try to post some pictures later.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
Thanks for the link with pictures emmett!
I want to make it as big as possible. My Dad has one in his shop at work that you could fit a bicycle frame in it and still have room to turn it 180 degrees. I don't think I will go quite that big. Seeing while blasting is an issue that I'm trying to work out. I am considering hooking up my shop vac to keep it clear. My Dad's is a cyclone so it sucks all the time. Do you think I need to line the inside with sheet metal?
Designated A-hole!
I am going to modify a 55 gallon drum and make a cabinet out of it. I am going to use a siphon blaster and a shop vac. It should do what I need done.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
I am intrested too
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour. - George Washington No free man shall be debarred the use of arms - Thomas Jefferson Later Darren ![]() http://www.myspace.com/dmurphy68 |
I haven't thought about using a drum. That might be a really good idea. I think I can get ahold of those blue plastic ones (like antifreeze comes in) but I don't know where I would get a metal one.
I talked to a fellow in a store a while ago and he told me that he had modified a commercial sandblast cabinet in a manner. I plan to do the same after listening to him. He used an airbox from a junkyard car (Taurus I think). Basically he ran the air through the automotive air filter on the way to his shopvac in order to reduce the wear and tear on the shopvac. Sounds like a good idea as you will need the shopvac to keep the dust down inside so you can see what you are doing.
I bought an inexpensive metal unit and then sprayed the inside of it with rattle cans of rockerguard in the light tan colour in order to protect the inside somewhat and to improve the lighting as it is hard to see. I have the small flourescent light but I need more. I'm gettting old and it is harder to see than when I was a young whipper-snapper. ![]()
1968 Chevy - 292 with a powerglide |
I wonder if I could use the shop vac as my hopper and run my line from the shopvac hose outlet up to the gun.
![]() Join Date: May 2002
Krue: Excuse my ignorance, but
what's a "siphon blaster"?
Stepsides look like real trucks! Smitty ![]() |
Designated A-hole!
For about $20 bucks you can get a gun with a hose that you drop in a bucket of sand that "siphons" the sand out of the bucket. Essentially the same thing a cabinet gun does at half the price.
Hammer On!
![]() Join Date: Jul 2001
Since we are on the subjects of sandblasting... Does anyone have a home built sandblaster? Not the cabinet kind. I'm looking for a good set of plans to build one out of like an old propane bottle or something. Lemme know what you guys have found or built!
Aaron ![]()
1968 C20 Inline 6 250 SM465 4 speed 1968 K10 Inline 6 250 SM465 4 speed |
#15 |
If you use a shop vac for the air evacuation, use a pre-filter. Shop vacs tend to cover the filter pretty quickly and will burn out much sooner than if you use a seperate canister inline.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
