Old 02-17-2017, 02:11 PM   #1951
Vic1947
Vic1947's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
Originally Posted by hotrod1 View Post
Thanks for the great explanation. I think I will try it. Any other settings on the Dynasty? Have you ever pulsed it with SiBr.
My Dynasty DX is one of the earlier models (digital readout, analog knobs) and has no pulse feature. The only thing I do is turn the start amps down to the same setting I use for welding to keep it from burning a small hole thru thin sheetmetal when I light it up.
Originally Posted by jlsanborn View Post
That is coming together buddy! Not that I had any doubt you'd get there but I was sure clenching once you got into all that cutting. I can only imagine the mess I'd have on my hands at this point! tj
Thanks, John, I was holding my breath a few times myself. The fact that kept me going was that it was only a $100 experiment more or less. I could have run over to Classic Parts at any time and got a new bumper.
Originally Posted by Xeen View Post
It came out beautiful Vic, Impressive work!
Thanks, Brian!
Originally Posted by snipescastle2 View Post
Vic,
What? No paint ? You're slackin' seriously, outstanding work! I've just about have the engine buttoned up from the cam change. Hope to crank it up tonight or tomorrow evening.next project will be the power steering gear box, it seems my pitman arm seal is leaking pretty good, and its soaking the bump stop rubber bumper and every time I turn right it would spit out the rubber bumper....$10 a shot. Time to get it done. Have a good one!
Ben
Hey Ben, glad to hear you're getting SB sorted out. As for paint... I'm underway with the body work. Filler now on both fenders and starting work on the tight spaces. Fortunately, 75% of the fender mods are hidden under the bumper.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 02-18-2017, 07:23 PM   #1952
Vic1947
Vic1947's Avatar
I know bodywork ain't the most glamorous topic... just didn't want you to think I was slacking off with all this good weather we've been having. Well, maybe a little bit.
Victor
Old 02-18-2017, 08:14 PM   #1953
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looking fantastic!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-21-2017, 08:35 AM   #1954
Low Elco
Beddy Beddy nice.
Low Elco is offline   Reply With Quote
Old 02-21-2017, 09:01 AM   #1955
jaros44sr
jaros44sr's Avatar
Vic, you nailed it, nice work
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-22-2017, 09:17 AM   #1956
snipescastle2
snipescastle2's Avatar
Talking Re: Crusty Rusty Leaky Squeaky 67 Step
Vic,
Lookin' good! won't be long now! by the way, how did your bed situation with the new chassis mods turn out? did everything fall back into place afterwards? I finally got my truck fired up yesterday, need to do a little "Finesse" on the tune, but it's running again. I kinda miss the lope I had with the old Cam, but the drive ability factor is better, and the clanking noise I had been hearing is long gone, I'm guessing that balancer was "Ringing" the pulleys during deceleration causing that clanking sound, because no matter how hard I tried, I could not get it to do it again....
now to fix my steering gear box leak.....
Have a good one and I'll stop by one day here soon.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 02-22-2017, 09:20 AM   #1957
Bennett68C10
Bennett68C10's Avatar
Awesome job Vic!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-25-2017, 05:52 PM   #1958
Vic1947
Vic1947's Avatar
Originally Posted by Ol Blue K20 View Post
Looking fantastic!
Originally Posted by Low Elco View Post
Beddy Beddy nice.
Lookin' good! won't be long now! by the way, how did your bed situation with the new chassis mods turn out? did everything fall back into place afterwards?...
Originally Posted by Bennett68C10 View Post
Awesome job Vic!
Thanks, guys!
Bed ended up in a much better place than before, thankfully. I'd probably be under supervised care if it hadn't.
The front bumper is pretty much solved with the exception of spot filler, a coat of slick sand and blocking. I used some fine line tape to lay out the gap I wanted between it and the valance. Some careful sanding and filing and it looks pretty good. I've turned my attention to the rear to tidy it up a bit. I picked up a painted rear fleet bumper at Classic on Monday and took both it, and the front, to Eagle Stripping. They returned the front bumper to clean white metal everywhere and removed the EDP from the rear bumper. I only plan a few mods out back. I'll narrow both sides to tuck in closer to the quarter panels, make a filler panel to eliminate the gap and weld in the fasteners to smooth out the bumper. Shouldn't be anywhere near the level of pain I endured up front.
Victor
Old 02-25-2017, 05:54 PM   #1959
Vic1947
Vic1947's Avatar
Some starter shots of the rear for reference...
Victor
Old 02-25-2017, 05:55 PM   #1960
Elliot949
Elliot949's Avatar
That has,worked in great Vic...can't wait until it is primed so we can see all the lines... Great work buddy ..
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 02-26-2017, 12:15 AM   #1961
Ol Blue K20
Doing great Vic. Keep up the great work. It's going to be a fantastic looking truck!
Dale
Old 02-26-2017, 02:50 AM   #1962
swamp rat
swamp rat's Avatar
Wow!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-27-2017, 09:02 AM   #1963
Low Elco
Love the front. Looking at the rear, wonder if you could make an angled slice on the ends to tip the bottom in and take the "bulge" out of the base? Just a thought.
Old 02-27-2017, 07:09 PM   #1964
Vic1947
Vic1947's Avatar
Getting closer, Dan, but I'm not nearly as fast as you with the body and paint.
Thanks, I appreciate it!
Originally Posted by swamp rat View Post
Wow!
Hey Mike, good to hear from you. Weather up there lately sux from what I hear... good time to lay low and lurk on the forum.
Thanks, Chip, we think a lot alike. I knew the ugly ends on the rear would need a bit of hammering. After I got them cut off, I used the press, vise and dolly to reform the edges similar to the front. I then tacked the shortened pieces back together and put the bumper back in place. Used some tape to mock up a filler piece that follows the line of the quarter panel a bit better. I sawed out a piece of mild steel flat stock using the tape as a template and have it taped in place in the last photo. All the mounting bolts have been welded in and smoothed out also. Not sure if this look is what you envisioned, but being a fundamentally "straight line between two points" person, this how I approached it.
Victor
Old 02-28-2017, 07:19 AM   #1965
Pick
Pick's Avatar
Vic, even though I've seen pictures of the stuff that has fought with you, you still make it look so easy and virtually seamless. As usual, I am very impressed by your work and your approach!
I must figure out how to straighten my line(s) between two points. My tiny little mind tends to wander and overcomplicate stuff WAY too much!
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 02-28-2017, 09:27 AM   #1966
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the bumpers and body Vic! looks great!
Old 02-28-2017, 01:33 PM   #1967
Low Elco
Diggin it!
Old 02-28-2017, 06:45 PM   #1968
knomadd
knomadd's Avatar
You do some nice work Vic! The front turned out great. The back looks like you're already on a good path. Keep it up!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-01-2017, 07:13 PM   #1969
Vic1947
Vic1947's Avatar
Nachos Garcia, everyone! I've only been able to spend a few hours in the shop due to other stuff that needed tending, so not much progress. The filler pieces for the ends are tacked on and I modified the bumper mounts very slightly to get the fit I wanted. Next up is to weld some 1/8 x 1/4 flat bar on the ends of the filler pieces to give them a more finished look. Then it will be time for the filler between the bed and the top lip of the bumper. Stay tuned.
Victor
Old 03-01-2017, 09:55 PM   #1970
Ol Blue K20
I'm very impressed Vic. I always liked the rear bumpers the way they came from the general. But it's looking awesome, I may have been wrong. I'm looking forward to see it completed.
Dale
Old 03-03-2017, 08:18 PM   #1971
Vic1947
Vic1947's Avatar
Thanks, Dale. I agree the stock bumpers look pretty dang good on this series truck. Looking back a month, not sure if I knew then what I know now that I'd drag out the cutting wheel. Might have been working on things that actually make the truck run by now.
Spent all day yesterday taking Dad to doctors and the ER. Thought he might have a fractured hip, but the CAT scan turned up gallstones and a cyst on his kidney. I reckon walking must have put pressure on that area and he was reacting to the pain. Anyway, he's doing better today and I was able to sneak downstairs and get some welding done. The ends are taking shape and I'm pleased with the edge I added. Now just need to do the other side.
Victor
Old 03-03-2017, 08:48 PM   #1972
jeh
jeh's Avatar
Vic, you nailed it on the front bumper.... I've looked at some trucks at the shows and always thought of how good that looked. As far as the rear, I would of never thought about doing what you've done, it looks awesome as well. Keep it up and get some paint on that thing.
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 03-04-2017, 12:40 AM   #1973
sduckworth13
sduckworth13's Avatar
X2 what Jason said . Awesome work Vic!
Scott
sduckworth13 is offline   Reply With Quote
Old 03-04-2017, 08:30 AM   #1974
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Hope your Dad is doing alright.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 03-06-2017, 09:04 AM   #1975
Low Elco
I like the way the back came out. Good job!
