Think i got my wheel dialed in
Think i finally got it were it needs to be!
Allen |
Re: Think i got my wheel dialed in
Well centered there.
Looks good there.
Kim |
Thanks Guys,
Embarrassed to say I had it in at the mark Flat out engineering plans calls for (from front of frame back to center of crossmember 27.5 inchs) well i put it in and thought that i had the wheel centered and welded it in, Well after double checking after i was over zealous with welding it in i found that i was an idiot and had the wheel to far forward, I couldn't live with it so cut it back out and hate to say the Mistake cost me $211.00, had to buy new coil spring mounting brackets and C notch piece's. After My Son Convinced me to move it back 2 more inchs I am allot happier with it and it would make seance as 58-9 frames are suppose to be 2 inches longer at the front frame horns? Allen |
![]() ![]() Join Date: May 2015
Yep ..looks good from here..
Better to spend the money than have to live forever with something that annoys you every time you look at it.
good job, better to do it now than later.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
Got my C-notchs moved back 2" and a little more welding and grinding
I should have them back were they belong, also filled in the recess area were the stock steering column went. Allen |
Looks good.
Kim |
It's always a good idea to correct it now.
The wheel looks centered in the fender. May the Forum be with you. . |
Glad to hear 58/59's are longer as my 57 seems good at about 5/8 forward of the 27 1/2 from front.
How to tell when your getting old--- Aunt B starts looking good! |
58CameoAZ or anyone else with FO front on 58/59... couple questions:
What was the final distance you settled on from center of the wheel to frame front? How did you work with the boxing plates fitting weird in relation to the c notch and crossmember... did you trim it and scoot it forward or is it supposed to primarily box behind the crossmember? Thanks!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
