anyone upgrade their headlight on a 91 blazer k5?
have not found anything myself yet
1991 K5 Blazer 4x4 "9 ball" 2019 Chevy Silverado Trail Boss 4x4 2018 Chevy Colorado 2 door ZR2 4x4 1988 23' Mako Marine 2005 Harley Davidson Road King |
Re: anyone upgrade their headlight on a 91 blazer k5?
Yes, I put a set of Hella H4 E code headlights in mine. I also added relays to the wiring. Huge difference in light output but not cheap. The stock headlights are absolutely pathetic.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
wow that is good news really was hoping for a set of LEDs but that sounds better than what i got for sure
thanks man
#4 | |
Another option would be making your own projectors but that would require a lot of fabrication. These housings are not very common and were only used on a few models. The Camaro's and Firebird's used this size housing as well as the Jeep Cherokee Limited's and that's about all that comes to my mind.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift Last edited by Edahall; 02-19-2017 at 10:11 AM. |
I will look into the Hella. Since my truck is hella cool. Lol
Posted via Mobile Device |
4wheelparts $165 for 2 pair no relay included? did the relay come from?
Rampage H4 Headlamp Conversion Kit (Clear) - 5089927 Rampage | Part Number: RPP5089927 This part fits your vehicle: 1991 CHEVROLET BLAZER BASE V8 - 5.7 Liter - GAS Change Vehicle Rampage - Rampage H4 Headlamp Conversion Kit (Clear) - 5089927 | 4WheelParts.com Rampage - Rampage H4 Headlamp Conversion Kit (Clear) - 5089927 | 4WheelParts.com Rampage - Rampage H4 Headlamp Conversion Kit (Clear) - 5089927 | 4WheelParts.com Click to Enlarge 3.8 Read 4 Reviews Qualifies for Free Shipping Technical Details Rectangular headlights Headlights are a direct replacement 60% more luminescence and D.O.T. approved Kit includes a pair of durable die-cast aluminum housings with s Questions(1) Answers(1) Overview Instructions Product Specs Update your dim stock headlight bulbs to a set of Rampage H4 Conversion Headlights that are a direct replacement, 60% more luminescence and D.O.T. approved. This is a simple 10 minute installation that requires only a screwdriver and the results will be incredible. Kit includes a pair of durable die-cast aluminum housings with solid clear glass lens and 2-H4 55/60W Bulbs. Imagine a whole new brighter nighttime driving experience that’s safer and less fatiguing.
1991 K5 Blazer 4x4 "9 ball" 2019 Chevy Silverado Trail Boss 4x4 2018 Chevy Colorado 2 door ZR2 4x4 1988 23' Mako Marine 2005 Harley Davidson Road King Last edited by schpeen; 02-19-2017 at 01:37 PM. |
I'm not sure those headlights will fit your 91 K5. I believe they are 150mm by 92mm or 5.9 inches by 3.6 inches roughly. The ones I have are made by Bosch and use Hella H4 bulbs, P/N HL21001
I wired up my own relays but you can buy the kit also.
![]() Join Date: Mar 2016
LED headlamps use to struggle with throw, but it's not the case now. They've closed the gap and exceeded HID and Halogen. I currently run Hella HIDs on my Jeep (same 7" round hole as the Blazer). I just installed a set of Lightforce 215mm LED flood lights. It's laughable how much more light the LEDs are capable of producing compared to the HIDs. As for the '91 headlamps. I'm not sure about the options out there. The 7" rounds are so great for options.
#10 | |
Power: 108 W Raw lumens: 7794
#11 | |
![]() Raw lumens won't really tell you a bunch. |
Swap to a base model core support and run JW Speaker 8900's.
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
That is super sharp
