Old 02-18-2017, 10:36 PM   #1
hotrodder
need help with gas guage please
I have a 65 GMC . Could someone tell me what color the wire is that supplies the power to the gauges. and also what color is the wire for the gas guage sending unit. It appears some of the wires have been cut where the plug is at the back of the dash.
hotrodder is offline   Reply With Quote
Old 02-19-2017, 08:56 AM   #2
PGSigns
PGSigns's Avatar
Re: need help with gas guage please
This thread should help. http://67-72chevytrucks.com/vboard/s...d.php?t=378484 Also if you go through the FAQ section there are other threads on wiring.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-19-2017, 11:43 AM   #3
hotrodder
Thanks for the reply. What I have been struggling with is trying to figure out the wires that go to the connecter that plugs in the back of the dash. I had to rewire the truck and I don, really understand the printed circuit. Wish it was just the old fashion guage
Old 02-19-2017, 06:01 PM   #4
ray_mcavoy
Chevy trucks used a pink wire for the +12V switched ignition feed to the gauges and a tan wire for the fuel gauge sending unit. Wire colors for your GMC might be different though ... I don't have a GMC specific wiring diagram handy to check.
Here is a good write-up explaining how to test the fuel gauge --> http://6066gmcguy.com/Electrical-02.html
And this paragraph in particular from that site might be helpful to you concerning the connector on the back of the dash:
Check the plug on the back of the gauge panel, check the incoming side at the post lettered "D" & "E". "E" should be power to the dash, "D" is to the sender. Check the printed circuit board on the back of the dash, (GMC Only). Look for brake in the printer on circuits. Repair anything found bad.
ray_mcavoy is offline   Reply With Quote
