Old 02-19-2017, 08:04 PM   #1
custom10nut
custom10nut's Avatar
Minor score at the yard, Part Deux
Thanks to Andy I found ABUNCH of the wiper mounted washer nozzles, so they'll be going on "the Mistress" soon.
Another cool item I found was a retractable under hood light (from a 97 Tahoe).
It'll work better than the Mercury switch one I have now
custom10nut is offline   Reply With Quote
Old 02-19-2017, 10:14 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Minor score at the yard, Part Deux
Cool!
If you have a electric garage door you need to grab the home link out of a GM are Ford they are all the same. You hook a 12 volt and ground up and program it to your door.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-19-2017, 10:34 PM   #3
saxart
saxart's Avatar
Originally Posted by Andy4639 View Post
Cool!
Just a tip...
Some of the older Homelink remotes won't work on some of the newer openers without buying a "repeater". We've got an '02 Merc Grand Marquis that doesn't play well with our new Chamberlain opener. Just a heads up..
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 02-19-2017, 10:45 PM   #4
Andy4639
Old member
Andy4639's Avatar
Originally Posted by saxart View Post
Just a tip...
Any of the 2012 up GM H/L should work fine. Ford I'm not so sure about but the GM do well as long as the garage door is a revolving code one.
Here are the 2 I have and both work fine. The one in the ash tray doesn't have as much reach but I figure it's because it's inside the ash tray.
