Old 02-21-2017, 10:44 AM   #1
A1971Blazer
A1971Blazer's Avatar
Fuel rail setup question
I'm in the process of getting parts gathered up in anticipation of the LS1 swap into my '70 K/5....
I created a rendering of the fuel feed set-up after looking at several pictures posted by members here....
My main question is...would it be necessary to add a schrader valve at the end...in order to purge trapped air from the rails....?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-21-2017, 11:47 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Fuel rail setup question
I do not have one on mine and it works fine.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-21-2017, 11:47 AM   #3
ls1nova71
ls1nova71's Avatar
You don't need to purge the air out of the rails, it will do that when the injectors open. If you didn't have a permanent gauge on the rail it would be handy for hooking a gauge up to it though.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-21-2017, 09:09 PM   #4
LS short box
When I did my LS swap with a BBK intake and aftermarket fuel rails I put a "t" in the fuel line feeding both rails on the back side of the fuel rails. Then kind of hid the fuel line behind the intake. I haven't done the Schrader valve or pressure gauge.
Old 02-22-2017, 08:19 AM   #5
A1971Blazer
I considered that as well....it looks to be foolproof in just about any configuration...thanks to all who responded.
1967 C10 Step side
1968 C10 Step side
Old 02-22-2017, 11:39 AM   #6
sprint_9
sprint_9's Avatar
I thought about doing mine this way as well, have the crossover on the back, and nothing on the front
sprint_9 is offline   Reply With Quote
Old 02-22-2017, 12:55 PM   #7
Hart_Rod
Hart_Rod's Avatar
I personally like having both, but not necessary.
Hart_Rod is offline   Reply With Quote
Old 02-23-2017, 09:29 PM   #8
A1971Blazer
I liked that idea....I need a couple more fittings.....to complete it....sent the injectors for cleaning and flow testing....
1967 C10 Step side
1968 C10 Step side
