Old 02-21-2017, 04:13 PM   #526
Clrussell
Clrussell's Avatar
Re: Let's Build A 1 Ton Crew Cab 4x4
Originally Posted by NastyBuzzard View Post
I can have them made by my current vendor but that will inflate cost. If you can give me a little time then yeah, I can have exactly what you want for a good price. With or without the buzzard emblem cut in! Actually that will be removed for our actual "company logo."
Works for me. It just simplifies the 2wd to 4wd swap process so much!
61 apache
Clrussell is offline   Reply With Quote
Old 02-21-2017, 04:18 PM   #527
NastyBuzzard
NastyBuzzard's Avatar
It most certainly does! & I am not sure on your application but designing one to use LS mounts as well. So no adapter brackets needed from dirty dingo or wherever.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 02-21-2017, 04:29 PM   #528
Clrussell
Clrussell's Avatar
Plan on buying a 454 2wd and swapping it to 4x4 keeping the 454.
61 apache
Old 02-26-2017, 07:52 PM   #529
Wide Open
Once you are done with the brackets for your SRW D60 any interest in making a set for a DRW version? I would be interested. The rotor wouldn't be free floating but I don't care. I'm just interested in the brake upgrade.
Wide Open is offline   Reply With Quote
Old 02-26-2017, 07:54 PM   #530
Wide Open
Heck if you want to get crazy and make brackets for some kind of D44 upgrade I'll take a set of those too.
Old 02-26-2017, 09:04 PM   #531
NastyBuzzard
Hey man! It can be done! Just need one of them DRW axles!! I'm not opposed to Dana 44!
Old 02-26-2017, 09:19 PM   #532
Wide Open
Well then we are in luck! I happen to have both of those axles not more than 800 miles from you 😂
Old 02-27-2017, 08:44 AM   #533
NastyBuzzard
Excellent I will just take a week off work to try and round them up! I wish it was that easy anyway.
Some progress. Dropped axle to drill holes out for larger 7/16 hardware. Some modifications to my front axle perches are necessary to use the larger hdw so have to update my design.
Wish I had the extra $ do drop on some 2" lift springs, I can already tell these 4" ones are going to be too high for me.
Painted on the NV4500..
Finished the welds and last bit of parts for the plasma. We rolled her big ass outside, washed it and prepped it for paint.
Finally after getting the paint problem sorted, we got some primer on it.
Should be ordering controls for it soon!
Also my rear brake conversion brackets are due here this week!
Old 03-01-2017, 05:33 PM   #534
NastyBuzzard
Painted black, all that's left is to paint the water table portion.
New design for the dana 60 brake brackets.
Still waiting on my damn rear brake conversion brackets... :/
Show off my buddys unfinished design for ford dana 60 4 link swap.. For anyone whos interested.
Old 03-01-2017, 07:57 PM   #535
Clrussell
Clrussell's Avatar
Man those brake brackets look good..
Just cut your own brackets for the rear.
61 apache
Old 03-01-2017, 08:19 PM   #536
NastyBuzzard
Can't cut my own rears... they are milled out of a .75" thick block of mild steel.
Old 03-03-2017, 03:16 AM   #537
wildwilly4x4
Im wanting to run new ford axles on my next build. may have to look into his kit if I don't build my own. Looks well thought out!
wildwilly4x4 is offline   Reply With Quote
Old 03-03-2017, 03:16 AM   #538
wildwilly4x4
know if he plans to include the upper coil mounts?
Old 03-03-2017, 09:15 AM   #539
NastyBuzzard
It is definitely well thought out. We have designed it w/ using parts made from the plasma. We are engineers and he has worked on perfecting the suspension geometry as much as possible. He also has a simpler tube design. We can also sell just the flat parts for you to weld yours together yourself.
Yes he will have upper coil mounts designed. He is also designing it to work with airbags.
Old 03-03-2017, 01:38 PM   #540
daddyjeep
daddyjeep's Avatar
I am liking the front brake upgrades that you have done. I may have to get a set of those brackets off you at some point. I have way too many other things to get done before I can look at that though.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-13-2017, 10:28 AM   #541
NastyBuzzard
Got a few things done.
Prototyped my brake setup, finally!!
My friends also came over and we set the engine in the frame after getting her back on her front wheels.
Anyone know where I can find the hardware to attach the ac setup to the firewall? I have lost my hardware.
Showing my oil pan clearance w/ my xmember.
I need to spend some money on clutch and what not to get the trans in and start wiring and plumbing this thing up!
Old 04-03-2017, 08:22 AM   #542
NastyBuzzard
Next revision worked like a charm!
Even tested drivers side.
Also worked on getting the NV4500 in.
Is there a cover for this??? Would love to find it and get one.
Cleaned up the Tcase.
Painted pedals as well.
Anyone know what size bolts it takes to mount tcase to the trans? I lost mine.
Still need hardware to mount the ac box back on as well. No clue where that went.
Old 04-03-2017, 03:49 PM   #543
mcmlxix
Collector of Projects
mcmlxix's Avatar
Nice work on the rear disc conversion.
Rich
1972 K5 Blazer CST Click HERE
Old 04-03-2017, 03:57 PM   #544
NastyBuzzard
Thank you! In a couple of weeks I will have the adapter for sale
Old 04-09-2017, 08:09 PM   #545
83GMCK2500
Bellhousing cover for the diesel engine/starter: 15699054
Bolts: 3911926, which I think is just a 3/8-16 x 1" bolt of grade 8ish variety.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-10-2017, 07:21 AM   #546
NastyBuzzard
Woo! Why are people charging so much for that cover! Looks like I will be making my own.
Thank you for the bolt size. I ended up using about 3/8-1.5" and now I know why that was a pain in the ass. 1" would have been so much easier, those 1.5" took forever to thread all the way in. Lesson learned.
Did some more tinkering with driveshaft lengths. Was able to swap one I had for a longer one at the junkyard but I overestimated and got one 2" too long so got to go back and swap for a bit shorter one. Just excited I was able to swap and save the $ I was going to spend on getting a shaft made. Seems I need one around 76", the 78" one is the exact length from the axle flange to the back of the tcase.
Also got the trim piece I have been needing for the bed for free!! Needs a little bit replaced on it b/c of rust but it fits perfectly!!!
Latest and greatest of the brade adapter arrived!
This spring has to be used, AC delco hardware kit, dorman one comes with a normal spring that rubs the hub.
So since I noticed the rear axle was a bit forward b/c of my flip bracket I made. I ordered some EZ inch, new Ubolts and the Ubolt flip bracket. So I had to drop axle. Hopefully, I can get all that in soon and axle back under.
Also for reference this is the diameter of the oil cooler line piece for the 6.5.
If all goes to plan I should be going to pick up an 02 2500HD 4x4 DirtyMax this week. It will be our CutBros. truck, at least it is a start. We have intent to design lift parts for it as well.
Old 04-17-2017, 07:56 AM   #547
NastyBuzzard
So I hope I did this right.
I know it is a little crooked... I need a deeper 15/16 socket.
Lets compare: (Should have moved back 1-1/2")
Before:
After:
I also went and did some driveshaft hunting...
Found a winner!
Ends up with 2-1/2"s of "penetration." Looks good enough to me!
Now to figure out how my DShaft angles look and see if I will need shims.
Also, I need a friggin shaft for the front. I have heard to find a dshaft from a truck with 4L80e/NP241. So we shall see.
I also picked up a 02 duramax, it needs injectors and what not but seems to be a good truck. It will end up being for the business.
Also, small update on the plasma table. We are wiring it up!
Next priority is getting this truck to fire up!!!!
Old 04-17-2017, 02:33 PM   #548
MTCK
MTCK's Avatar
Good work! You are making good progress.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 04-18-2017, 08:48 PM   #549
deejaaa1
love those D-Max rims.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 04-18-2017, 09:06 PM   #550
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work and you guys are making some good progress with your business. Are you marketing the rear disc mounting brackets or are they available some where else?
Ryan
1969 Chevy milk truck
