Old 02-22-2017, 10:14 PM   #26
vince1
Re: Adding a power brake booster to a '65 C-10
I think I gave erroneous information. Maybe front reservoir goes to front brakes and rear reservoir goes to rear brakes.
vince1 is offline   Reply With Quote
Old 02-23-2017, 01:46 AM   #27
Captainfab
60-66 Nut
With a '67-'70 master cylinder, the front port is front brakes and the rear port is rear brakes.
Old 02-23-2017, 01:48 AM   #28
Captainfab
60-66 Nut
As long as you have all the correct pieces, that booster and master will work. Do you have the booster mounting parts and the long intermediate pushrod?
Originally Posted by kevinjr View Post
1964 C 10 Cant you use 1/4 inch lines all the way with a dual MC front & Rear .What is the reason they down size to the 3/16th to the rear lines from the rear tee Junction
I found a OEM Booster do i mate it with a 67-72 C 20 Master Cylinder
Thanks in advance
Old 03-17-2017, 10:05 AM   #29
nxtruck
nxtruck's Avatar
Once again, Captainfab is correct. This is 100% correct. I found out the hard way after a few near-misses with mine plumbed the opposite way. The rear wheels will lock up easily and the front brakes will not get enough fluid pressure with the plumbing reversed.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 03-17-2017, 08:39 PM   #30
vince1
I have noticed no difference in performance from the old single cylinder which obviously gave the same pressure to front and back. Captainfab is sure to be correct in the line routing but I doubt if the dual cylinder changes the pressure between front and rear ports. If that were the case we would be needing to change slave cylinder sizes at the wheels.
