02-23-2017, 09:29 PM | #1 |
Gas pedal question
My 67 has an interesting gas pedal, two ball studs at the bottom hold the pedal to the truck, and it slides at the top.
With the new carpet, I can't get the pedal to stay on the balls. I'm wondering if anyone here has adapted a different type of pedal, one that does not rely on a mount at the bottom. If so, I would be interested in how you did it. |
02-23-2017, 10:08 PM | #2 |
Re: Gas pedal question
Not a ton of help....but you can switch over to a '71-'72 pedal/cable assembly. It takes a little work, but will work.
Jimmy Hoelzel |
02-23-2017, 10:08 PM | #3 | |
The Older Generation
Here is one thread on it.... http://67-72chevytrucks.com/vboard/s...d.php?t=669995 There are a lot of threads on the subject. LockDoc
02-24-2017, 11:21 AM | #4 |
Thanx, I will try to find some of the other threads, did not think of that. Was hoping for a quick, not replacing the whole thing trick
02-24-2017, 11:34 AM | #5 | |
I don't think there is an easy answer. You might try replacing the ball studs to see if that helps, but that is not always an easy task either. If you don't heat the old ones before trying to remove them they often twist off and have to be drilled out and the holes re-threaded. LockDoc
02-24-2017, 01:42 PM | #6 |
Sometimes the carpet is just too bushy around the balls and you have to trim some back.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-24-2017, 03:16 PM | #7 |
02-25-2017, 12:08 AM | #8 |
02-25-2017, 08:13 AM | #9 |
Old member
Best money you will spend on a gas pedal assembly.
http://67-72chevytrucks.com/vboard/s...d.php?t=689764
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-25-2017, 11:22 AM | #10 |
lol
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-25-2017, 04:09 PM | #11 |
02-27-2017, 09:15 PM | #12 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Welded this late '70s early '80s firebird/ trans am unit to the original lever and it works flawlessly. Well it has for 349,000 miles so the test drive continues.
03-03-2017, 02:32 PM | #13 |
I like that Capt. I was just about to pay 50.00 for the kit, I'm gonna look for a way to duplicate yours before spending the money.
03-03-2017, 07:37 PM | #14 |
I like that solution also captrmw. In my case I would have to check on how to make the old mounts not noticeable with my existing carpet.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
03-03-2017, 08:07 PM | #15 |
And I will have to find an old gas pedal..
07-27-2018, 02:55 PM | #16 |
Finally got around to this. It's a project and just now getting to where I'm driving it. Followed Capt. RMW's lead and bought a used gas pedal on Ebay (8.00, from a 70 Barracuda). I think that's pretty cool in itself.
Well, got it welded, and the test drive is underway
1967 C-10 4-speed, 350v8 |
07-27-2018, 03:05 PM | #17 |
save your time and money, take a small box cutter to where the balls are and cut them through
07-27-2018, 04:45 PM | #18 |
lol again
07-27-2018, 09:55 PM | #19 |
Custom Sport W/T
Looks good Dave, I am still "road testing" mine after 29 years and 480,000 miles. We are in Deming,N.M. on the last third of an 8500 mile trip.
Later, Capt. Roger |
07-28-2018, 12:14 AM | #20 |
Oh man, I just saw this right after I trimmed the bushiness from my balls on my 69 truck and installed the pedal onto the new carpet. I should have been paying attention and done it this better way. Yes that does look very nice, both of you.
07-28-2018, 02:34 AM | #21 | |
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
08-22-2018, 10:36 AM | #22 |
This is brilliant. If mine falls off one more time it is out the window
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
08-23-2018, 08:21 AM | #23 |
Thanks for the idea! I'm going to look for another pedal next time I'm at the pick-n-pull.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
08-25-2018, 11:46 AM | #24 |
I have come across this a few times, I simply remove jute, from the pedal area of the carpet, and problem is solved.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
