02-23-2017, 11:10 PM | #1151 |
Re: Nik's 62 build
The backside
02-23-2017, 11:14 PM | #1152 |
Re: Nik's 62 build
And a front view.
I brought my tires to the school shop the other day and got them mounted, so I'll put up a pick of those tomorrow.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
02-24-2017, 01:41 AM | #1153 |
Re: Nik's 62 build
Good job man, it'll look good in there.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-24-2017, 10:22 AM | #1154 |
Re: Nik's 62 build
Nice job on the gauge panel. That really fits the look of the dash.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
02-24-2017, 10:31 AM | #1155 |
Re: Nik's 62 build
The seatbelt tailgate latches are awesome, there is a guy here locally that did it on a 50's model....COOL IDEA!
1965 Olds 442 "Project Oldmobile" 1971 2wd GMC Jimmy..."The Orangutan" 1961 Apache "The Ape" http://67-72chevytrucks.com/vboard/s...d.php?t=679735 |
02-24-2017, 10:59 AM | #1156 |
Re: Nik's 62 build
That gauge pod is going to look great, nice work!
02-24-2017, 10:05 PM | #1157 | ||
Re: Nik's 62 build
Thanks tj!
Thanks Scott! Here are some pics of the tires mounted on the rims, I put the hubcap on just to get an idea of how it will look. I'm extremely happy about how good these look especially with the caps, the tires are not overly aggressive but they're still rough enough to get the job done |
02-24-2017, 10:07 PM | #1158 |
Re: Nik's 62 build
Another shot
02-25-2017, 01:29 AM | #1159 |
60-66 Nut
Re: Nik's 62 build
Very nice work on the gauge pod
02-25-2017, 08:50 AM | #1160 |
Re: Nik's 62 build
I am digging the gouge pod as well. The tires and wheels look great. Cool.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
02-25-2017, 09:20 AM | #1161 |
Re: Nik's 62 build
Gauge pod and tires look good Nik!
02-25-2017, 10:22 PM | #1162 | |
Re: Nik's 62 build
Thanks John, means a lot coming from someone with your skill level
Thanks bill! Today was quite the busy day! I don't have any pictures to share at the moment but I got up early and spent some time sanding the other inner fender and got it prepared for paint and spayed the first coat of black on it and pulled out the other inner fender and put the second coat on it. I then spent the rest of the day replacing the timing belt on the family minivan, it all went smoothly. Tomorrow I'm hoping to get the the gauge pod mounted under the dash.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution Last edited by 62stepside longbox; 02-25-2017 at 10:49 PM. |
02-27-2017, 03:11 AM | #1163 |
Re: Nik's 62 build
Temperatures dropped back down today and it started snowing unfortunately, but I still got some work done. I drilled a hole and installed a neat looking Chrome toggle switch into the gauge pod. Not entirely sure what I'll use it for yet, but I'm sure I'll find some use for it.
02-27-2017, 03:12 AM | #1164 |
Re: Nik's 62 build
Mocked it up on the dash for the first time and started to make some brackets to mount it, that's as far as I got today. So far I'm really liking the way it flows with the humps in the dash
02-27-2017, 02:16 PM | #1165 |
Re: Nik's 62 build
Looks good man, we got some snow to. Was hoping to get some truck time in, but I ended up having to do some work on the GMC instead and then spent the rest of the weekend with my girl. haha
02-27-2017, 02:46 PM | #1166 |
Re: Nik's 62 build
*****in...
That really does flow well with the dash Nik, well done buddy. |
02-27-2017, 04:48 PM | #1167 |
Re: Nik's 62 build
Your gauge pod and my A/C vent pod and brothers!!!
02-27-2017, 07:52 PM | #1168 | ||
Re: Nik's 62 build
Thanks! And you're right!
03-01-2017, 10:31 PM | #1169 |
Re: Nik's 62 build
I got the one inner fender polished out and installed on the truck, the drivers side one still needs a second coat.
03-01-2017, 10:35 PM | #1170 |
Re: Nik's 62 build
Since I switched to power brakes I had to make some space on the firewall, I did this by removing the windshield washer reservoir. So I needed to relocate it somewhere else in the engine bay. Here is what the stock bracket that mounts to the firewall looks like.
03-01-2017, 10:36 PM | #1171 |
Re: Nik's 62 build
So I bent the tabs a bit different so I could mount it on the passengers side inner fender.
03-01-2017, 10:41 PM | #1172 |
Re: Nik's 62 build
This is how it'll mount
03-01-2017, 10:47 PM | #1173 |
Re: Nik's 62 build
Makin progress!
03-02-2017, 12:57 AM | #1174 |
60-66 Nut
Re: Nik's 62 build
The other stock location for the washer reservoir is on the drivers side of the radiator support above the horn relay.....just sayin'
03-02-2017, 04:28 AM | #1175 |
Re: Nik's 62 build
Good problem solving.
Inner fender looks good, in fact, you should be very proud of your build.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
