02-24-2017, 01:04 AM | #26 |
Re: Rear brake upgrade: 11 to 13
LMAO. Ass transplant! I gotta register there. Nice 14B. I gotta ask, where in the hell does the Oreo come into play? Does it help calibrate the dial indicator
I didn't read it all of the way through. Do you like the ARB? Ive got a Gov Loc. It hasn't given me any problems but if it were to go, I was looking at either ARB or an OX Locker type setup. I have a "thing" about things locking up when Im not expecting it.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
02-24-2017, 12:01 PM | #27 | |
Windy Corner of a Dirty Street
The verdict is still out on the ARB as the project is far from complete. I just got the axle under it yesterday afternoon and still need to set up the pinion angle and shock arrangement. I havent even gotten a compressor or air tank or even started laying out the front Bilstein 7100 shock layout yet. Got a long ways to go but I have until June when Desert Trip 2017 is booked. The G-Van axle looks wider...My eye micrometer says about 1.5 on each side [/url]
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
02-25-2017, 02:14 AM | #28 |
Funny how you say that its wider. Does it even out with the front?
I had no clue that my old 60 was nearly 3 inches narrower than the front until I got the 14B home and found it was actually 5 inches wider than the 60. After the initial freak out subsided, I realized that it actually lined up the front / rear track a little better. 3/4" wider in the rear on each side. I keep thinking that maybe if I keep some Oreos around, that the kids may help out a little more.... realistically though, Id end up needing an assplant Cant wait to hear how the ARB works for you. If anyone would use it like its supposed to be used, it would be you. Keep up the good work! Looks great!
02-25-2017, 09:14 AM | #29 |
true van width rear 14ff is 70" wms to wms . reg srw pickup rears are 67" and c&c is 64" . a dana 60 srw front is 69" .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
06-11-2017, 11:37 PM | #30 |
I'm going the other way, from 13 to 11 inch drums. I'd rather lose the weight than carry around a capability I'll never use. I'm swapping in a 14FF/dana 60 combo from a cucv into my 85 3/4 ton.
My only question is regarding the wheel cylinders. Are they different diameter/capacity and if so, does it affect the stock master cylinder? Thanks for sharing the info Larry. Mike |
11-29-2017, 06:49 PM | #31 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by Liz; 11-30-2017 at 08:45 AM. Reason: edited by staff please review forum rules thank you |
11-30-2017, 02:17 PM | #32 | |
I went with discs on my 14bff so FREE to a good home 13"drums and backing plates. Of course you have to pick them up.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
11-07-2018, 07:44 PM | #33 |
Can anyone help???
I have a 1987 Chevy suburban 2500. It is a 350 gib with th400 trans. 4X4 it started life with a 9.5” semi floating rear. The carrier had a lot of slop and I had a 10.5” full floating rear out of another truck. Ever since I installed it the stopping power has been horrible. All of the rear brakes are new except drums which were cut and well within tolerance. I didn’t change the booster or master or proportioning valve. Also my truck still has the rear weight/level sensor and the brake lines do go through it. But they always did. My other two suburbans are a 1982 3/4 two 2wd. And I can lock it’s brakes up if I push the pedal too quickly. It is a 9.5”. Am I just expecting too much from the 10.5” brakes? Thank you in advance for any help or suggestions I really appreciate it. This is my plow truck and I’m trying to get it figured out before the snow flies. Again thank you! |
11-07-2018, 10:34 PM | #34 |
first thing those load valves love to go bad and freeze up . by pass it .
then looking up the 87 burb master cylinder part #'s . 11" rear brakes was aluminum / plastic tank master with small bore size . 13" rear brakes was cast iron master with bigger bore for more fluid flow . so if bypassing and bleading the rear dosnt help the next step is bigger master to match the bigger rear brakes . but also double check the brakes are adjusted in the rear . self adjusters dont do crap most of the time . jack up the rear so tires are off the ground and click them up till just starting to scuff the drum face .
12-11-2021, 10:37 AM | #35 |
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher 85 K30 SRW 350 TH400 NP205 4.10 87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher 83 K2500 350 TH700R4 8600GVW Dual Tank 4.10 1973 Cheyenne Super 30 DRW Std Cab Z83 4.10 1976 Silverado C30 Std Cab 4.10 DRW (4 sale) Last edited by 57taskforce; 12-11-2021 at 10:07 PM. |
