Old 02-25-2017, 05:53 PM   #1
jeff messenger
? ON DOORS 69 thru 72
? On Doors 69 thru 72. O.K are the doors on the big flatbeds the same as the pickups. The truck im talking about is maybe a c-50 or so I know the bottom corner is on an angle for wheel opening but the rest of the door looks the same to me looks like I could change the skin from bodyline down and it would work.I mean this cab looks just like pickup dash glovebox door all the same even the floor hump that unbolts looks the same ANYONE out there know for sure I would like to buy these doors and rebuild them.
Thanks for any input Jeff
jeff messenger is offline   Reply With Quote
Old 02-26-2017, 01:24 AM   #2
randy500
Re: ? ON DOORS 69 thru 72
Same door they actually cut the corner off with a saw. I have used them before.
randy500 is offline   Reply With Quote
Old 02-27-2017, 03:19 PM   #3
jeff messenger
Randy500 Thanks I went up and bought them today just change lower skins and I have a good set of doors.
Old 02-27-2017, 03:41 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Yep, good deal. I have them on my '72 cab and they worked out really good....
A friend of mine and I put the floor pan out of a C50 in his '69 K10 and it fit good. All we had to do was to modify the front corners by the kick panels and the center of the tranny hump. The pans are usually in good shape too.
LockDoc
Leon
Old 02-27-2017, 03:44 PM   #5
randy500
Your welcome. Those can be in really good condition for some reason. I just welded on the corner from a door that was damaged when I used them.
Old 02-27-2017, 07:12 PM   #6
jeff messenger
Yes they are pretty nice one little rust hole on each in the bottom corner cut out weld in easy fix. Think the doors on these stay so nice cause there high off ground. Oh LOCK DOC The floor in this one real nice also thought about it but replaced my floor pans already and running out of room to store.
Jeff
Last edited by jeff messenger; 02-27-2017 at 07:17 PM. Reason: forgot to add something
