Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-25-2017, 11:23 PM   #1
black_k5
black_k5's Avatar
72 blazer ls swap
So I'm fare lyrics new to the site and purchased my blazer about 6 months ago. I love driving it so much I did a lot of research on this site and decided I would try my first ls swap. I will start by saying thank you to everyone for all the info. I'm hoping that this build might help someone else. After gathering some parts I started my project right after Christmas.
Since I did not want to stop driving the truck and wanted a lift kit I decided to start with a second frame. After having it sand blasted we added some bracing to help stiffin the body for towing. I decided to use a 31 gallon tank from a 87 blazer to be able to have an in tank fuel pump. To mount it I took 2 pieces of 2x2 angle and welded them together. This aligned to the rear set of rivet holes for the bump stop mounts. The original gas tank brace will need to also be moved back to fit the tank. This aligned with a set of holes already in the top of the frame to give you a reference point.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
black_k5 is offline   Reply With Quote
Old 02-25-2017, 11:28 PM   #2
black_k5
black_k5's Avatar
Re: 72 blazer ls swap
Here is some on the reinforcement I did to the frame. The biggest improvement came from boxing in the original crossmember. For that I used a piece of 2x3 square stock and cut it to fit.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 02-25-2017, 11:36 PM   #3
black_k5
black_k5's Avatar
Once the gas tank was fitted it was time for paint and reassembly. I por 15 everything then top coated with Eastwood chassis black but had issues with drying, it took over a week to cure. Not sure that was a good combo to use. After that the 4" rough country lift was installed with 3/4 ton axles from a 86 suburban
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 02-25-2017, 11:47 PM   #4
black_k5
black_k5's Avatar
I landed a 2002 suburban with 140k miles. 5.3l and 4l60e. Since my blazer has a np203 I decided to go back to a np205 and bought the AA adapter kit. I was going to fabricate a new cross member but due to time I ordered a dirty dingo crossmember. Once that comes in I can start on the brake lines.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 02-26-2017, 12:01 AM   #5
black_k5
black_k5's Avatar
As for the fuel system I decided on trying the poly fuel lines after reading hemi43's thread. I bought a factory sending unit for the 87 blazer and cut off the flare fittings. Dorman sells a repair kit that has 2 12" lines with the quick connect ends. You can cut them to length then use a flaring block and swage to expand the pipe. Then brazed them together with 45% silver braze. Then added an Acdelco ep381 fuel pump that plugs right into the sending unit. I still need to find a fuel filter that has the quick connects. I think the early 2000s mustangs will work.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 02-26-2017, 12:17 AM   #6
GMC-YA68
GMC-YA68's Avatar
Looking good so far! You did your homework!
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 02-26-2017, 01:24 AM   #7
SPIFFAV8
SPIFFAV8's Avatar
Subscribed.
SPIFFAV8 is offline   Reply With Quote
Old 02-26-2017, 08:58 AM   #8
black_k5
black_k5's Avatar
Thanks Keegan. The idea of a second frame and the tank setup came from you. I've probably read your build about 15 times now.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 02-26-2017, 09:26 AM   #9
A1971Blazer
A1971Blazer's Avatar
Nice build....I'm subscribed....
Spare frame for me too....
I just got it in the shop and mounted to the rotisserie yesterday
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-26-2017, 01:33 PM   #10
hemi43
hemi43's Avatar
Looking good!! You won't regret using the ploy lines, just keep them away from chaffing and the exhaust. I used a standard fuel filter like the one on your 02 donor, because it used the same connectors as the ones on the fuel sender and fuel rail. BTW, we like lots of pictures !
hemi43 is offline   Reply With Quote
Old 02-26-2017, 03:08 PM   #11
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Good stuff,
Post good pics of the fuel system. I am doing the same.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-06-2017, 12:05 AM   #12
GM man
GM man's Avatar
Keegan, you didn't have to move your cross member to mount that 31 gallon tank, did you?
1972 GMC Jimmy 6.0/4L65
1972 Chevrolet long bed 1/2 ton
GM man is offline   Reply With Quote
Old 03-06-2017, 03:36 PM   #13
1rippen6
subscribed
1rippen6 is offline   Reply With Quote
Old 03-06-2017, 07:06 PM   #14
GMC-YA68
GMC-YA68's Avatar
Yes, I moved it back a few extra inches but forget why. It may have been because the filler neck would have been right in the way of the body mount.
-Keegan-
Old 03-08-2017, 10:22 PM   #15
black_k5
black_k5's Avatar
Yes the cross member needed to be moved back or the gas tank would be over the axle.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 03-08-2017, 10:30 PM   #16
black_k5
black_k5's Avatar
Alright so I got the dirty dingo crossmember and proceeded to paint and assemble it. There are quite a few bolts. Also I'm showing the holes that had to be drilled in the frame to mount it. Notice that you use one existing hole to mount it and one of the other holes gets very close to an existing one. Theyou do provide plates that go on the outside of the frame which I haven't installed yet.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 03-08-2017, 10:44 PM   #17
black_k5
black_k5's Avatar
Here is the motor installed. I used anchor 2292 motor mounts off rockauto for the frame. As for the motor side I ordered a set of IFS mounts to save some money from the dirty dingo mounts. I had to trim the tabs off the passenger side anchor mounts to allow for easier install. Since I'm running a truck pan it was very close to the crossmember as others have stated it would be. It the wording on the pan was grinder down it would allow for more clearance. I added 2 3/8" washers between the motor and IFS motors which comes out to around 1/8". I thought about making a steel plate for a spacer but the washer aren't loosing any surface area for mounting.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 03-08-2017, 10:47 PM   #18
black_k5
black_k5's Avatar
More pics
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 03-08-2017, 10:57 PM   #19
black_k5
black_k5's Avatar
So the only issue I have now is the secondary transfer case mount, which I know was not standard on all blazers does not line up. The crossmember came with the frame so I know it's correct. The transfer case was a Craigslist find and came with the secondary bracket. I believe the transfer case is stamped 72 though and the rubber mounts are new. It's looks to be about an inch off. I'm not sure if I should shim up the transfer case or just not use the other mount. Any ideas?
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 03-08-2017, 11:14 PM   #20
1rippen6
I see the rubber mounts on the front tire take a picture installed on the inside of the frame rail maybe something there is switched around. I know someone will know how it should look if not I can find the picture in the body and chassis manual if it comes to that.
Old 03-08-2017, 11:17 PM   #21
GMC-YA68
GMC-YA68's Avatar
My bracket looks like it comes down further than that (I think). Do you have the rubber mounts in between the bottom of the t-case and crossmember installed?
-Keegan-
Old 03-08-2017, 11:21 PM   #22
GMC-YA68
GMC-YA68's Avatar
Here is what mine looks like. Maybe suck the bracket mounts down? I don't see any vertical bolts on yours.
-Keegan-
Old 03-08-2017, 11:24 PM   #23
black_k5
black_k5's Avatar
Dwyane, I am just holding the bracket in that picture. Friday i will mount it in with the rubber. I looked at a few pictures of this site to see how it mounted
Keegan I do have new mounts between the crossmember and the AA adapter mount. I did not take a picture of that but there there.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
Old 03-08-2017, 11:41 PM   #24
GMC-YA68
GMC-YA68's Avatar
Mount the bracket with the rubber and see where you compare to the pics I just posted. I have another bracket that is 72 correct if we still think that one is too shallow...
-Keegan-
Old 03-10-2017, 10:46 PM   #25
black_k5
black_k5's Avatar
Your not hijacking, as all the questions you want. I also could not find that info. I started my own mounts then gave up. So it was easier for me to reference the head. With a straight edge laying on the frame and touching the rear mounting bolt webbing on the block, the head is slightly over an inch. I'd say 1 1/8"
I also took a picture of the gas tank to axle spacing so show why the original gas tank brace gets moved back.
Anthony
1972 K5 4x4
1969 Camaro SS
1987 Grand National
1985 Cutlass
