02-25-2017, 11:29 PM | #1 |
Factory vacuum gauge
Hi guys, was just looking at the tach thread and i wouldn't want to cover up my vacuum gauge. how many of you have a vacuum gauge there? 70 gmc custom. BROWN 70
02-25-2017, 11:32 PM | #2 |
Re: Factory vacuum gauge
I've never seen one like that. Cool stuff!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-25-2017, 11:33 PM | #3 |
That's a mid-60's Pontiac vac gauge. There were no factory vac gauges in 67-72 in Series 10-30 trucks. Med duty had them (a different, smaller one than that), and many folks retrofit them into the unused gauge opening to the right of the column (where the Med Duty's had them).
02-26-2017, 03:58 PM | #4 |
I bought the truck in 1980 and I got it from the original owner. he was a farmer and pulled a horse trailer with it. everything on the truck was numbers matching when I bought it. I don't think he put that gauge in. it has a grommet in the fire wall were it passes through to the pass side vacuum port on my q-jet. I met the owner of a 67-72 parts shop and he said he had seen one or two others like mine. one thing I,ve learned in this hobby is there are exceptions to the rule. I use mine a lot for mpg, and how the engine is running. have a great day, BROWN 70
02-26-2017, 04:27 PM | #5 |
It's a nice set up, but not factory. Not in the Tach hole. Is it listed on the SPID? Maybe a dealer add-on, but why a Pontiac gauge? Pontiac dealer? Could be, since it's a GMC.
I run an aftermarket [MoonEyes] Vacuum gauge in a shinscraper mount along with mech water temp, and mech oil pressure gauges. I have the Standard [idiot light] dash with 3 hole, not the 7-hole Deluxe. Love my Vacuum gauge. Good on long trips for getting cruise throttle right. Saved the day a couple of times when valve springs broke and I could read on the dash that I had valve problems. Great for tuning up the carb. When I look at the instruments and see 750 RPM, 180* water temp, 40 PSI oil pressure and 17" Hg, I know my engine's running right. An under-appreciated instrument, the Manifold Vacuum, IMHO.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-26-2017 at 04:45 PM. |
02-26-2017, 05:27 PM | #6 |
Looks like the only answer is to have a full teardown! Pontiac wasn't the only one with vacuum guages. I have a no name one that I pulled off the console of a seriously rusted two door 62-64 Impala back in the mid eighties. I would have to pull it down from the attic to see if it is an exact match. It was the only good part left on the car.
02-26-2017, 05:34 PM | #7 |
Agreed and well stated
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-26-2017, 05:52 PM | #8 |
Thank you, Sir. You're a gentleman and a scholar.
02-26-2017, 07:14 PM | #9 | |
If you've had it since 1980 though and it's been there, it's original to you, so I wouldn't get rid of it unless you REALLY wanted a factory tach.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-26-2017, 09:45 PM | #10 |
Active Member
I dont think its factory installed.
As jocko said the medium duty trucks C/40, C/50 & C/60 basically used the same dash as our light duty trucks, and they did have an optional vac gauge it filled in the blank spot on the lower left in the gauge cluster. The blank spot where you have the vac gauge is for the optional Tach. We have also seen guys put after market tachs and clocks in that spot. Another way to know is there is no reference to a vac gauge in the owners manual |
02-26-2017, 10:22 PM | #11 |
Good point HO455, Pontiac was not the only GM make to use these - but, they were all GM. The little faceplate that hid the needle base usually carried the Pontiac spear or the Chev bow tie on it. Many were console mounted mid-60's in a chrome cup. Here's the one I stuck in my 66 dash a while back. It's a great gauge, adds a little color to an empty spot and is semi-useful. 2nd pic is one of about 8-10 on ebay right now from $100-$400 ish. Just google search Pontiac Vacuum Gauge and you'll find a slew of them.
