Old 10-06-2001, 11:31 AM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post Traction bars
I have a 72 chevy with the leaf spring rear end. I lowered the front two inches and the rear 1.75 with shackles and then took the overload and middle leaf out to get it level. Now when I get on it I have alot of wheel hop. Does anybody make traction bars for my truck or do I have to get universal?
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 10-06-2001, 02:06 PM   #2
Randy70C-10
Randy70C-10's Avatar
Post
With leaf springs, pretty sure you have to use universal (road slappers). Just be careful not to get suck on any speed bumps!
Randy70C-10 WWW.Randysrods.freeservers.com
1970 Chevy C-10 shortstep
30 Model A Coupe 4 inch chop, 350, GMC 671 blower-Hell yeah it's fast!
87 Harley Sportster(couldnt get a 350 to fit)
Self Propelled Lawn Mower
Built in USA!!!!
Randy70C-10 is offline   Reply With Quote
Old 10-06-2001, 02:39 PM   #3
69 longhorn
Post
I have universal slappers on my longhorn,but the axle has been flipped. With the Axle in stock location,the brackets on the universal bars will be way too short. I dont know of anybody that makes bars for our leaf trucks,but you could build a set pretty easily,or modify the brackets on a universal set. that was 1 nice thing about the coil rears....they didnt wheel hop!Good luck.-----------------HotrodHorn
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 10-06-2001, 05:54 PM   #4
nate68
Post
theres a guy on here with a 73-87 that had some custom made ones and they look pretty slick. i heard that traction bars won't work unless the leaf springs go under the axle, so you gotta do a flip for them to work (i'm not 100% on this but i read something about this somewhere)
you could always blow a ton of money and get a 4 link setup. air ride tech. has 4 link air ride conversions for 67-72 leaf trucks. i saw an article where they did a suburban.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 10-06-2001, 06:52 PM   #5
69 longhorn
Post
I think you can make those slapper bars work with the axle under or over the spring....You just need to limit the clearance between the snubber & the spring to 1-1 1/2". they will be easier to set up with the axle over the spring though.
Old 10-07-2001, 06:28 PM   #6
mldenniscc
Post
On the subject of leaf rearends. How much trouble would it be to convert to coils with track bars? I didn't know until last weekend that there was a such thing as a coil rear. --MD
FOR SALE: 72 lwb c10 custom, ps pb, .5 a/c, straight body, some rust, Need to sell ----
98 zr2 xcab 5.7 liter white nuf said
mldenniscc is offline   Reply With Quote
Old 10-07-2001, 07:43 PM   #7
69 longhorn
Post
The frames are different,the coil frames kick out (at about axle centerline) to make room for the coils to sit.---------------------------HotrodHorn
Old 10-09-2001, 09:18 PM   #8
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
If I put the stock springs back in it and flip the axle will I have to C-notch the frame?
Old 10-09-2001, 11:36 PM   #9
69 longhorn
Post
Yes,you are lookin at about a 6" drop with stock parts & flipped axle.....or you can take the spring brackets off the frame,& move em down along with the flipped axle ,to give a little less drop. I set my longhorn up that way,& have about a 5" drop. Clearance is limited(3 1/2" between the frame&axle),but I dont do any hauling so it works.Good luck.....HotrodHorn.
Old 10-15-2001, 01:30 AM   #10
LeRoy
Registered truck nut
LeRoy's Avatar
Post
I put a set of traction bars on my 70 K5 Blazer. They sit on top of the axle, held down by u-bolts and run up to the frame. You drill a hole and run a pin through them so you can also get full suspension drop while offroading, with pin romoval. You'll have to convert to newer style u-bolts with nuts on top of axle instead of under. Ran me about $80 at the local LES SCHWABB tire dealer.
MOUNT VERNON, WASH. STATE
GOT MY BASES COVERED
-Big and bad 70 CST Blazer
-71 K5 Blazer, 350, 4spd, 2" lift, 35" BFG mudders, Camo,
-Work in progress 72 SWB
-72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd.
-71, 3/4 ton, 402/400, Custom Camper
-69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER"
-69 Chev., lwb, utility trailer, 35" tires,
-88 1ton BB workhorse
Add or Delete Daily
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 10-17-2001, 01:46 AM   #11
Fast68Chevy
Fast68Chevy's Avatar
Post
Lol @ mldenniscc
where you been all your life ? Most all(about 90% of them) the 67-72 Chevy trucks are coil spring rear, lol.
no offense meant
Fast68Chevy is offline   Reply With Quote
Old 10-17-2001, 09:14 PM   #12
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
Hey fast68chevy, I wish I had coils they are much cheaper to lower. Having rare stuff sucks! Hey Leroy, is there a way you could put up a picture so I could see how they go? What brand are they? Have you seen them on the net somewhere also?
