04-01-2004, 11:02 PM | #1 |
Not the nightly winner
drive shaft ?
hey guys,anybody running a one piece drive shaft with a 400 turbo,in a short bed truck.
if so what did you use or make,thanks todd
72C10SWB BLUE 350/350 86K10LWB BLUE 5.7 700r4 7.5' fisher plow 93S10XCAB4X4 BLUE 4.3 4L60e 69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green 86k15 swb5.0L 4spd brown |
04-01-2004, 11:14 PM | #2 |
thats a good question I am doing the same, 1 piece driveline with 400 and need to find out what to use for driveline
04-01-2004, 11:47 PM | #3 |
I have a one piece driveshaft from a gmc longbed that will need to be shortened, for sale if you are interested....
04-02-2004, 12:01 AM | #4 |
Life, Be In It.....
I have a one piece aluminum shaft from Denny's Drive Shaft, but I am running a 350 turbo.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
04-02-2004, 12:47 AM | #5 |
On the road
What I've done several times is find one at the junkyard that fit as close as I could find, preferably a little too long. My local salvage yard used to have stacks of them. Anyway I found that even though it was off a Olds or Pontiac where the U-joint clips are on the Inside I could use conversion U-joints ( inside clip to outside chevy clip) from the local Car Quest and make them work. I have had to have them cut down a couple of times though. If you don't cut too much off sometimes you can luck up and not have to rebalance the drive shaft. I have done this for 350 and also 400 turbos.
Mike |
04-02-2004, 08:57 AM | #6 |
tanker,you don't have a pic by chance do you?
04-02-2004, 02:46 PM | #7 |
I'll take one and post around lunch time.
04-02-2004, 02:54 PM | #8 |
its all about the +6 inches
If anyone knows the difference n short shaft TH350 and the TH400 (did 400's have long and short shaft versions??) then you may be able to go off my one pce shaft in my SWB small block TH350 truck. Mine is 4 foot 10 inches center of hole to center of hole.
04-02-2004, 05:42 PM | #9 |
-Chris
my driveshast
i got a driveshaft for my shortbed out of an old buick. I had to get it cut down a few inches though. the holes on the drive shaft were bigger than the stock holes for the u joint. i just switched out the caps. the reason i used this was because it was spare, but the race shope said that this driveshaft was better to use. I sandblasted it and powdercoated it and put her behind the th400. been working great since.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
04-02-2004, 11:10 PM | #10 |
#1
04-02-2004, 11:11 PM | #11 |
#2
04-02-2004, 11:11 PM | #12 |
#3
