Old 02-28-2017, 11:08 PM   #76
James the III
Re: If you like destruction -
Originally Posted by BossHogg69 View Post
I haven't checked the spring pressure, they're still on the heads. I gave the spec sheet to the shop that set up the heads, and I didn't check them myself after he set them up.
Not asking if the springs where set up correctly..
I'd like to know if the spring is NOW at the correct spring height and if the on seat and open pressures are still in spec.. As this will tell you if the spring lost strength and allowed the valve to float..
if many of the springs installed height is wrong.. you'll see that now.. but I'd want to measure more than just one for this. as the fails spring if it weakened will most likely be shorter now than when installed..
James the III is offline   Reply With Quote
454, bbc, big block, big block chevy
