Also needing a driveshaft
I have read quite a few threads here about driveshafts. One common recommendation is not to trust anyone else's measurements, as all installations are a little different. I hate to ask the same questions as previous threads, but my case is a little different than any I have read. Here is what I have:
2000 LM7 with 4L60E swapped into LWB 1968 C10 with coil springs. trans is mounted to stock 1968 crossmember with 2000 isolator. Distance from back face of 4L60E tailhousing to center of diff u-joint = 71.25" At normal stance, measurement from centerline (trans output to diff u-joint) to bottom of crossmember is 2.25" Distance from 4L60E tailhousing to crossmember is ~30", crossmember to axle is ~50" If I use a 3" 1-piece driveshaft, I will have 0.75" clearance at normal stance, and will not hit the crossmember until the axle drops 1.25". Is this enough clearance? I like the simplicity of a 1-piece driveshaft, but am not sure it's the right way to go. TIA for the input. The information here has been invaluable so far, and I'm sure someone out there has recommendations for this one as well. Thanks! |
![]() Join Date: Jan 2011
Re: Also needing a driveshaft
1 1/4" is not much travel at all. I would say it would be a problem. If you want to go one piece I would go Aluminum at that length and mod the cross member.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
So I'm committing to a 2-piece driveshaft rather than modify the crossmember. Any recommendations for donor vehicles? Hoping to find TH350/4L60E yoke, short shaft, and carrier bearing from the same vehicle. ALL driveshaft/machine shops within 120 miles recommend bringing in driveshafts to shorten rather than starting 100% new.
![]() Join Date: Feb 2014
Dennys drive line cheaper stronger guaranteed
Tags |
drive shaft, ls swap, lwb |
