Old 04-02-2004, 03:27 AM   #1
69ChevyGuy
Question Need Pictures and info on shaving drip rails
Does anyone have any pictures or information on how to remove drip rails..so far i have removed the spot welds from the underside without breaking through...and have successfuly removed the biggest piece of the drip rail on the doors....from the a pillars to the front of the cab is a different story...it looks a bit more involved so i haven't done anything to that yet......i need info or pics asap......
Thank You
Cesar Mata
1969 Chevy Longbed
69ChevyGuy is offline   Reply With Quote
Old 04-03-2004, 10:26 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
This has been asked before so you might try "search"
but the advice that I have heard was to cut a small amount off then weld it up then cut some more taking it slow. There are three pieces that come together at this seam.
sneakysnake is offline   Reply With Quote
Old 04-03-2004, 11:08 PM   #3
cdowns
cdowns's Avatar
you shouldn't be cutting sections out that are more than 6inches long!!!!!
with a cutoff wheel cut out a 3-6 inch section then weld it up go to the other side of the cab and do the same section , repeat this sequence about 50times then grind the welds and putty it smooth and yer ready fer paint
