#576 |
Re: Bringing the '65 back to life
#577 |
Wow you are making this look easy.
#578 |
Thanks Bomp! I don't know about "easy", but we're still plugging along.
![]() We decided to get the brakes knocked out before the engine/trans go back in. A new master cylinder and rebuilt hydroboost unit arrived a few days ago, but it turns out that the hydroboost units do not come equipped with the necessary pushrod, spring, disc, and retainer. Luckily, Dad was able to snag these parts by scrounging around a local junk yard. We whipped up the necessary mounting plates, as well as a bracket to hang the Wilwood adjustable proportioning valve, and stuck the assembly on the cab today. ![]() |
#579 |
Dad knocked out the lines today (one line not shown here) while I figured out the pedal situation. The lines will get a few tweaks at final assembly, but they're all formed and flared. The pedal required an extension to relocate the hole for the pushrod, as well as a little bump to actuate the brake switch which previously rode on the pushrod in the original location. I'm not sure how well the pedal ratio is going to work out, as that is a heck of a lot of leverage for a power-assist setup (over 6:1), but we'll see how it feels.
Everything will get paint this week, and should go back together one last time next weekend. ![]() |
#580 |
Clockwise from top left: Finished paint and pre-assembly of the brake parts this week. Installed the Wilwood front calipers this morning, then the brake pedal, master cylinder/booster, proportioning valve, and lines. Afterward, we hooked up the power bleeder and bled the system. Finally, we drilled a big hole in the floor to allow the PCM wiring to pass through under the seat.
#581 |
#582 |
#583 |
We knocked a bunch off the list today. Intake, fuel rail, throttle body, water pump, and dampener are installed, amp is moved to the passenger side, PCM is mounted in the center, pass-through grommet is fit to the cab, fuse panels, relays, and TAC module are in the process of being mounted and wired...long busy day.
#584 |
#585 |
#586 |
Diggin the progress
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#587 |
Thanks Don. It might be a long shot, but we're trying like crazy to have this thing cruise ready by this September.
Dad and I hit a swap meet this morning, then he blasted and primed parts while I started on a mounting plate (red box) for the accelerator pedal assembly (blue box). Once it's mounted, I'll have to make a new arm to connect it to the stock '65 throttle pedal. ![]() |
#588 |
Dad had to clearance the frame a bit for the hydroboost pump return lines before installing the driverside FEAD. I bent up some round stock to adapt the late-model accelerator pedal assembly to the original '65 accelerator pedal. It's all welded up and painted, and it should be installed next weekend.
#589 |
#590 |
We spent some time laying out the "trunk" today. The box mounting is complete, the fuel tank mounting and supports are complete and painted, and the battery tray has been welded up. Once the battery hold down provisions are complete and those parts are painted, the box will be ready for final install into the bed.
#591 |
#592 |
#593 |
Shifter Saturday. Clockwise from top left: I wish we would have noticed when rebuilding the column that the lockout tab for Park was wiped out. A little welding and filing later, we have a solid lockout. A Lokar ACA-1800 shift linkage kit with a ACA-1832 rod fit right up after cutting to length and adding a few slight bends.
#594 |
Great Progress!!!
#595 |
Thanks Don. We're working our tails off to get this thing done by September.
Not a particularly exciting day, but progress nonetheless. As we plan to relocate the fill on the fuel tank, we spent the morning whipping up a block-off plate and a new bolting flange. We also assembled the new coil mounts so we can figure out the best location for them. ![]() |
#596 |
#597 |
#598 |
#599 |
I didn't get a chance to post this last Sunday (5/7):
We might be hurrying along to get this thing done by September, but we're not about to half-ass anything. The toolbox nameplate was replaced by one of our own doing this morning. Dad also knocked out a few filler panels for the front fenders and did a little bodywork while I did some wiring and put together a list of fittings and hose ends we'll need to plumb. ![]() |
#600 |
