Old 04-02-2004, 01:18 PM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
Question rear axle ratio question
What rear axle ratios were available for the following:
1967 1 ton dually (133 inch wheelbase), small block V8, 4 speed.
I'd like to know what was standard equipment and what the optional ratios were. This is a factory small block, so I don't need to know the I6 #'s.
If different, also list ratios for the single rear axle as well.
Thanks.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-02-2004, 02:33 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
All i could find written on the 67 C/30 rear options for daulies, is this;
From the '67 restoration packet option H-22 Capacity 11,000 pound, ratio 6.17 CS/CE314 models only, (cab/chassis) Available only with 4 speed transmission, power brakes, HD radiator,700-18/8PR or 8-19.5/10pr dual tires. Includes front and rear shock absorbers, 5900 pound each capacity main and aur rear springs, 15X4 rear brakes, 2000 pound each front springs, 10X2 1/2 drum and dual shoe parking brake.
Old 04-02-2004, 03:03 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Holy crap! Do you have any additional info from later years? How about single wheel rear axles as I'm not 100% convinced its a factory dually yet.
Old 04-02-2004, 03:06 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Here's what I'm thinking of buying
Yes it has a BB. But with those gears I may want to carry a gas pump, even though it has dual saddle tanks built into the flatbed.
Old 04-02-2004, 04:18 PM   #5
Longhorn Man
I can't locate it in the 67 pages, but the rule of thumb on the other years (and I am sure there are a couple variances) is small block with auto, got 4.10, and all others got 4.56. I think the (later) big blocks may or may not have had 3.-something. but that may be only on the smaller trucks.
I wonder how much of a mutt that sucker is, all the cab chasdsis trucks with daul rear wheels were supposed th have factory clearance lights, and those are either dealer add ons, or aftermarrket, so i knda wonder if that is a 67 cab on a what ever year chassis, or what?
Old 04-02-2004, 04:30 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Originally posted by Longhorn Man
I wonder how much of a mutt that sucker is...
No doubt about it. It is a 1 ton frame with drums all around. I will check the VIN and model # to see if any of it corresponds to a 1 ton.
I can tell you the asking price is well below what the for sale sign indicates and it's been maintained. Oh the dash isn't cut either but the roof is (sunroof)
It does have the sm420 and power brakes
Old 04-02-2004, 04:56 PM   #7
GMC71k20
brian, are you gonna use that for your company?
GMC71k20 is offline   Reply With Quote
Old 04-02-2004, 08:27 PM   #8
71402BB
now thats a true COON DOG
Yep, if we get it! I think we will though!
current project
67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!)
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well...
72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!)
68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!)
67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!)
71402BB is offline   Reply With Quote
Old 04-03-2004, 02:59 AM   #9
1969 GMC
1969 GMC's Avatar
well if it has the H072 rear axle, it could only have had 3 gear ratios from the factory. if it has factory duals, I would assume 5.14. The other two would be 4.57 and 4.11, but I am not sure how they assigned the ratios to different engines. I think I heard somewhere that if a C/30 had factory duals, then it came with the 5.14 gear ration, but I'm not sure if thats correct or not. And if it has the larger 11,000# Eaton axle, then it will be what Longhorn Man already said.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-03-2004, 03:13 AM   #10
Longhorn Man
I thought that sounded odd...these books read liek stereo instructions...so I probably mis quoted it. 5.14 sounds more likely.
Old 04-03-2004, 04:06 AM   #11
1969 GMC
1969 GMC's Avatar
you may be right...according to my '69 GMC service manual, there were 2 rear axles available for CM-,CS-, and CE/3500 trucks, and also for the PS- and PE/3500 vans. the standard was the HO72, which came with 4.11, 4.57, or 5.14 gears. Optional was the H110 (f), which resembles a HO52/72 except the diff cover isn't removable (welded on), and the axle is larger. I can only find one set of gears for it...6.17.
the (f) denotes that the H110 can be had only with the SM465 and IFS040 front suspension, and without the 396.
all that being said, I dont think I have ever seen one of these in a 67-72. International 1 tons of this era had an optional axle available called the RA-15, is similar to this axle, but higher gear ratios (4.88) were available for it.
1969 GMC K2500
1996 Honda Accord
