Old 04-02-2004, 02:49 PM   #1
jorgensensc
jorgensensc's Avatar
Wow, 4.10 rear end?
I finally got around to checking my rearend gears using an internet calculator.
Looks like I got 4.10s in the rear.
I run 3300 RPMs at 60 Mph.
I run 275/60r15 (28 inch tire)
Does this sound about right to anyone else?
I need better MPG's andwas thinking of running an overdrive tranny.
Should I keep these gears and get an overdrive, or just get different gears?
Anybody want to trade rear ends?? Mine is a coil spring rear?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-02-2004, 02:52 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if your truck is fairly origial, that would be listed on the glove box door.
Old 04-02-2004, 02:53 PM   #3
dinnut
dinnut's Avatar
id leave the gears and get an overdrive. that would be a great addition... but a gear change will be a lot cheaper!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 04-02-2004, 04:54 PM   #4
Lobo'74
Lobo'74's Avatar
I'm lookin' too.
Truck runs 2650 rpm at 60 mph running 31" tires.
Truck runs 3000 rpm at 66.5 mph, same 31" tires.
What equations do I use to figure out the rear end? I think its a 4:11, but I'm not positive. It is the stock 1967 I6 rear end that came on Truck originally.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 04-02-2004, 05:00 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: I'm lookin' too.
c10 = 3:73 stock I6 manual, 4:11 optional
c20 = 4:56 stock I6 manual, 4:11 optional
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-02-2004, 05:04 PM   #6
Lobo'74
Lobo'74's Avatar
FAST response
Thanks CPNE. I also did a web search and found a calculator while you were posting. Came back to the site and you had answered the question for me.
"Truck"
'67 small window
Old 04-02-2004, 05:30 PM   #7
70-Chevy
-Chris
70-Chevy's Avatar
im interested in swapping
what size rear end is it?
what lug?
i had a 6 lug, 12 bolt that i would like to have 4.10 in. let me know.
chris
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 04-02-2004, 05:36 PM   #8
LooseCannon
One way to be 100% accurate... remove the rear end cover and divide the number of teeth on the ring gear by the number of teeth on the pinion. It’s probably about time to change the 90 weight anyway!
LooseCannon is offline   Reply With Quote
Old 04-02-2004, 06:21 PM   #9
Longhorn Man
Loose Cannon...that's my line! (I normally answer with that for the past 3 years)
I'll add that avter 10 years, the oil is not doing all it should be doing. (acording to our indipendent oil lab we use at the shop)
Old 04-02-2004, 09:08 PM   #10
jorgensensc
I will probably take the cover off, but I just replaced all the fluid about 8 months ago. I stupidly didn't check then. This truck was an original 350, so I suppose the rear end was changed at some point. They didn't orginally come with 4.10 or 4.11 did they?
As for the glove box, the po removed the sticker and painted over the area when the truck was repainted.
450hp,
Mine is a 12 bolt 5 lug rear. I think shipping would probably be a little high from here to there though.
Old 04-02-2004, 09:26 PM   #11
cdowns
cdowns's Avatar
the computer game things are a fine tool but it makes the assumption that your speedometer is accurate
Old 04-02-2004, 09:49 PM   #12
my new 72
faster, faster, faster
my new 72's Avatar
I've got a 3.07 coil in mine I would like to trade.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 04-02-2004, 09:50 PM   #13
jorgensensc
I have driven by those speed trap things and my speedo is darn near on the money. My tach is also right on. T 40 mph on theres I showed 41mph.
Old 04-03-2004, 03:35 AM   #14
RON WOODGEARD
Resident Young Old Dude !
http://www.summitracing.com/landing/...converter2.htm
RON WOODGEARD is offline   Reply With Quote
