03-10-2017, 11:24 PM | #1 |
Hotchkis Upper and Lower A-Arm trouble
I have ordered and in the process of installing Hotchkis Upper and Lower A-Arms and CPP drop spindles in my 69 LWB. The trucks crossmember has been replaced with one from a 72 truck from a previous Disc Brake upgrade. The Upper A-Arms say they are designed to work with 73-87 spindles but say they will work with 71-72 if the upper ball joint is changed. I have changed the upper ball joint with the one they requested, however the upper and ball joints seem to be misaligned with each other with the lower one being about 3 inches farther forward, additionally the center axis of the spindle does not move on a level axis when moved side to side. I have added a photo of this. Any suggestion on this would be greatly appreciated.
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
03-10-2017, 11:35 PM | #2 |
Re: Hotchkis Upper and Lower A-Arm trouble
Can you please take a picture from above the upper control arm pointing down toward the ground. Just checking to make sure you don't have the two upper control arms mounted on the wrong side.
03-10-2017, 11:36 PM | #3 |
I'll try to get one tomorrow
03-10-2017, 11:38 PM | #4 |
You have the uppers on the wrong side!?
03-10-2017, 11:39 PM | #5 |
For ref |
03-11-2017, 12:20 AM | #6 |
Thanks for the ref pic
03-11-2017, 09:42 AM | #7 |
Are you sure you have each one on the correct side?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-11-2017, 12:48 PM | #8 |
motor exploder
Whatanerd - I'm using the same arms, and the pic 71bucket posted is correct, you definitely have the passenger side arm installed on the drivers side. The more steeply angled portion of the arm faces the rear of the truck.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
03-11-2017, 01:57 PM | #9 |
Thanks, the uppers were define reversed, working on correcting now.
03-11-2017, 09:50 PM | #10 |
Got the kit installed, live the trucks new stance.
03-12-2017, 01:32 PM | #11 |
Sweet. Glad you got it figured out
