Old 03-14-2017, 11:04 PM   #1
STP67-72
STP67-72's Avatar
70 4x4 suburban- wanting to go big block
I have a local guy wanting to put a bigblock in his 4x4 suburban. I was told to move engine forward for firewall clearance ?? Gives room for valve covers and HEI clearance ?? Will stock small block mounts work. It's a 350- granny 4 speed. Going 454 , t-400 etc. thanks for any and all help.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is online now   Reply With Quote
Old 03-15-2017, 01:25 AM   #2
kwmech
Re: 70 4x4 suburban- wanting to go big block
Much easier to pull the engine forward to the next set of bolt holes in the frame (You only have to drill one side) than pounding the firewall for the valve cover and the distributor if you've got an HEI. I have not put a big block in, but I know there will be an issue with the big block oil pan hitting the factory x-member with the small block cushions. You may want to try or measure the 2wd big block cushions. I know they are thicker.
Old 03-15-2017, 10:20 AM   #3
B. W.
B. W.'s Avatar
kwmech is spot on, when you move the engine forward you also need to check clearance between the engine cross member & the front axle. If springs are stock (and worn out) you may not have enough clearance. Also, with 350 mounts you will probably have clearance issues on the passenger frame rail with the exhaust manifold. Headers may solve this (or may make it worse.) I have have not done one but a friend of mine has a 71 K20 that he put a BB in. He did not change the mounts & had to notch the pass frame rail.
B. W. is offline   Reply With Quote
Old 03-15-2017, 05:14 PM   #4
ajviper
ajviper's Avatar
Replied in your original thread up in the Suburban section.
Chevy Runs Deep.
1956 210 LS1 TH350 3.31 Posi 12 Bolt
1969 Z/28 5.3 T56 3.73 Posi 12 Bolt
1973 Nova SS 355 TH350 2.73 Posi 12 Bolt
2000 K2500 Suburban LS 6.0 4L80 3.73 G80
2005 K2500HD CCSB LS 6.0 4L80 4.10 G80
2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic
ajviper is offline   Reply With Quote
