03-15-2017, 08:52 AM | #1 |
firewall pad insulation glue
does anyone what kind of glue that black tar like stuff was used by gm to glue the firewall pad on the interior firewall? i want to used that same type of glue/caulk on some other things. thanks
03-15-2017, 08:58 AM | #2 |
Re: firewall pad insulation glue
the firewall pad is held to the interior (cab side) of the firewall with rubber plugs, not glue.
03-15-2017, 09:07 AM | #3 |
the pad itself is held in by plugs but the upper part insulation on mine was glued in from gm
03-15-2017, 11:02 AM | #4 |
Ahh, I think you are referring to the part that moves up under the upper dash by the speaker. I think GM just used a high contact cement
03-15-2017, 11:34 AM | #5 |
yes , its all in the upper part of the dash, what type of glue could this be , it was some sort of black tar, not so much a contact cement but like a splatter of caulk
03-15-2017, 02:09 PM | #6 |
I have no idea, but I know it takes almost a blow torch to get the stuff off
03-15-2017, 02:49 PM | #7 |
I think that was just contact adhesive that was sprayed on, years ago that stuff was not black it was yellow on the ones I removed long ago.
03-15-2017, 05:32 PM | #8 | |
Here's one on the driver's side:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-15-2017, 05:44 PM | #9 |
thats it, you got it ., is the black tar like glue just contact cement? or something else?
03-15-2017, 11:49 PM | #10 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-15-2017 at 11:56 PM. |
03-16-2017, 02:02 AM | #11 | ||
03-16-2017, 02:24 AM | #12 |
The black tar was in the jute to hold it together and be water resistant. [Old tech.] They still used adhesives -- either 3M Weatherstrip Adhesive ["Supersnot''], or 3M 77 Contact Spray Adhesive.
In hot climates [like Tucson] the tar would melt in to the floor and firewall. I had to use a lot of turpentine and rags to get it up.
03-16-2017, 11:26 AM | #13 | |
03-16-2017, 03:37 PM | #14 | |
03-17-2017, 07:53 PM | #15 | |
I wasn't there when they built your truck. Could be different years and different plants may have had varying procedures. What year and what plant produced your truck? You have a '66 or earlier in your avatar.
