Windshield Sealant
I have been searching and cannot find what brand or type of sealant to use to run a 6" bead each direction from the upper corner of my windshield seal.
I have a leak that trickles down the side of the windshield to the hole at the bottom on the dash and fills my glove box with water... My seal is pretty new and very pliable. Small Sample: http://67-72chevytrucks.com/vboard/s...d.php?t=644511 http://67-72chevytrucks.com/vboard/s...d.php?t=358346
Can someone define what sealant to use instead of the vague stuff I am seeing? Also, do you seal the outside of the seal to the body or peel back the seal and apply under the seal where the body and seal meet at the pinch?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: Windshield Sealant
Look at the 2nd post on this thread:
http://www.chevytalk.org/fusionbb/sh...hp?tid/316693/ I have some of that sealer that I bought in 1982 that I just used on my truck for a small leak like yours. It will not harden and work great. Hugh |
![]() Join Date: Jan 2001
You should use a butyl rubber sealant. It stays flexible and doesn't cure like a urethane sealant. Whatever you do, DO NOT use silicone. It will eventually leak and nothing likes to stick to old silicone.
![]() Join Date: Dec 2013
Great answers! Thank you!
Do you seal the outside of the seal to the body or peel back the seal and apply under the seal where the body and seal meet at the pinch?
![]() Join Date: Mar 2013
You will need to peel it back and get as deep in there as you can. If you get the CR Lawrence applicator, run tape just under the edge of the gasket so you minimize the risk of scratching the paint.
And I just realized what you meant. Yes peel it back on the outside, and the inside. Use mineral spirits to clean up any excess.
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
#7 | |
I ended up getting this from Permatex. Lets see how it handles the rain the next couple of days.
https://www.permatex.com/products/ad...-glass-sealer/
I hope it works for you. In my experience (I owned an auto glass shop for many years) silicone is not going to permanently seal a leak, no matter what Permatex says.
![]() Join Date: Jul 2015
Are you sure it's not coming from the top of cab from the drip rail
I just went to a local auto glass shop and purchased a tube from them. I figured that if they were using it, it had to be good!
1972 GMC 1500 Super Custom, 383 Stoker, TH350 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592157 Engine Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592233 |
Tell me more...
Mine would leak a little every time I washed it I would see some water drops inside on the floor mat. I thought the same thing that the winshield seal was leaking, but it ended up being the seam sealer on the driprail was cracked and letting water inside the cab.
This is what will rust out inside the cab by the visors. The seam sealer gets hard with old age and cracks then let's water in and under it , then the water can get in between the 2 different panels coming inside
