Old 03-18-2017, 11:11 PM   #1
BCOWANWHEELS
exhaust thry x-member question
hey when you fellas run your exhaust pipes thru the x member how are you,all doing it. pic,s would be super.
thanks
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 03-18-2017, 11:57 PM   #2
rocknss
rocknss's Avatar
Re: exhaust thry x-member question
Here is a picture of my exhaust going through the center cross member on my 69 Suburban.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 03-19-2017, 12:07 AM   #3
BCOWANWHEELS
WHAT size holes did you cut and did yoy plate the crossmember . I,am gonna run 2 1/4 pipes
Old 03-20-2017, 12:07 AM   #4
rocknss
rocknss's Avatar
I had an exhaust shop build my exhaust. I'm running a 2.5" exhaust so I believe the holes are around 3" in diameter. The X-member is not strengthened where the holes are cut.
Steven
Old 03-20-2017, 12:20 AM   #5
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Sorry to hijack your thread but what sway bar are you using here in this ?
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 03-20-2017, 01:33 AM   #6
BCOWANWHEELS
stock sway barbut I have a adjustable one ready to go in
Old 03-20-2017, 12:16 PM   #7
RodnRudy
RodnRudy's Avatar
Here's a couple of pics of my cross member through holes. I used 4 1/2" tube by 1 1/2" wide and 3/16" thick. I picked up the tube from a fab shop down the road from me.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 03-20-2017, 04:46 PM   #8
BCOWANWHEELS
super rudy thanks. did you also flip the truck arm mounts
Old 03-20-2017, 05:00 PM   #9
RodnRudy
RodnRudy's Avatar
Yes I did flip the truck arm mounts but I changed them back because I thought there was too much pinion angle when I got the suspension loaded to ride height.
Phil
Old 03-20-2017, 10:41 PM   #10
BCOWANWHEELS
RUDY, how much did you drop the rear suspension. mine is 6-7 lowered lwb and is hard on carrier bearings
Old 03-20-2017, 11:34 PM   #11
tsetsaf
These look great. We have an LS and that exhaust gets really hot... we also have air ride with nylon lines. Real hot + nylon lines = sudden leaks. If your plans include anything plastic/ melty in the area consider heat wrap or insulation/ heat shields.
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 03-21-2017, 01:27 AM   #12
BCOWANWHEELS
no plastic on my truck
Old 03-21-2017, 06:55 AM   #13
RodnRudy
RodnRudy's Avatar
My 68 has a 5 1/2-7" drop but I have a one piece drive shaft.
Phil
Old 03-21-2017, 07:14 AM   #14
BCOWANWHEELS
rudy, is your truck lwb
Old 03-21-2017, 07:27 AM   #15
RodnRudy
RodnRudy's Avatar
No, short wheel base
Phil
Old 03-21-2017, 06:09 PM   #16
70c10resto
70c10resto's Avatar
http://www.azproperformance.com/Dead...63-72-C10.html
Here is a bolt in option also.
70c10resto is offline   Reply With Quote
