Old 03-19-2017, 03:25 PM   #1
suburban99
suburban99's Avatar
TH350 to LS 6.0. where does the kick down cable and vacuum hook to?
Swapping a LS 6.0 into my 72 K10. Is there a bracket for hooking the TH350 kick down cable up to the throttle? Where should I hook the vacuum for Tranny to? (drive by cable motor). Thanks
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 03-20-2017, 12:46 PM   #2
aruss99
Re: TH350 to LS 6.0. where does the kick down cable and vacuum hook to?
I had a th400, so I can only answer the vacuum question, but I used the brake booster line off the back of the intake for vacuum. Works just fine.
aruss99 is offline   Reply With Quote
Old 03-20-2017, 05:30 PM   #3
First c10
First c10's Avatar
The kickdown cable....Your probably going to have to connect it to the throttle cable somewhere
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-24-2017, 01:54 PM   #4
Jstock85
could you explain that please? I have a th350 and will doing the same thing. Did you take the hose from the brake booster, connect to it somehow, or is there another hose you are referring to?
Jstock85 is offline   Reply With Quote
Old 03-24-2017, 03:14 PM   #5
aruss99
My truck doesn't have power brakes, so I used the line on the back of the intake manifold, (approximately 1/2inch in diameter) that attached to the hose running to the original brake booster on the donor truck. I attached a fitting to the rubber hose with hose clamps to get the hose size down to 1/4 inch. Then I used regular vacuum line to to run to the transmission.
Hopefully this helps, if not, feel free to ask again for more clarification
Old 05-10-2017, 09:33 AM   #6
Jstock85
What did you end up doing to hook up that kick down cable?
Old 05-10-2017, 10:00 AM   #7
suburban99
suburban99's Avatar
I haven't hooked up the cable yet...but I have read you can use a longer one and connect it to the throttle..will post when I do figure it out.
2015 Ram 4x4 1500
1997 Boxster.
Old 05-10-2017, 10:05 AM   #8
Jstock85
Please do! I'm a few steps behind you and will be getting to that soon. Thanks!
Old 05-10-2017, 10:31 AM   #9
PunishedC10
I ran the vaccum hose from the ls1 intake to my brake booster. My hose still had the same connection on the brake booster end that popped right into the booster. I have a trailblazer ss/07+intake here that has the same hose on it as well. The 99-06 truck vacuum hose should also work this same way.
Maybe you could T into this one for the trans
1964 Coupe Deville(cruiser)
1966 Chevy II Nova 2door Hardtop
1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys
2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s
2000 Trans Am WS6, LS1/T-56, too many mods to list
PunishedC10 is offline   Reply With Quote
Old 05-10-2017, 10:44 AM   #10
Jstock85
You took the hose from top middle of manifold and ran to brake booster?
Old 05-10-2017, 06:45 PM   #11
PunishedC10
Yes, it had the connection that pop into the brake booster still on the end so it was easy haha
Old 05-16-2017, 01:00 PM   #12
Jstock85
Punished, you figure out what you going to do to connect the kick down cable?
Old 05-16-2017, 09:29 PM   #13
PunishedC10
I am running a 4l80e, I don't have to worry about it haha
Old 05-17-2017, 09:15 AM   #14
Jstock85
Got it. Thanks anyway!
