Old 03-20-2017, 07:10 PM   #376
donandal
Re: Plus Five
Thanks,
I made it with .060 thick 3003 aluminum.
I used an english wheel to curve it to match
the curve of the roof panel. It's slightly rounded
in both directions.
The front moldings at the visor area are also made
from the same aluminum. I rolled the profile to match
the look of the original headliner retainer... sort of.
Then I used the original retainer at the rear.
Kind of keeping a metal look to it.
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 03-20-2017, 09:55 PM   #377
MIKESAD50
Re: Plus Five
Amazing work! Like this truck. Wish I had small amount of your talent.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 03-21-2017, 04:45 AM   #378
RockinKees
RockinKees's Avatar
Re: Plus Five
WoW!
That's really nice!
Your eye for details is amazing!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 03-25-2017, 12:16 PM   #379
donandal
Re: Plus Five
My son was home today so we mounted the doors.
No major issues, and no paint damage getting it all lined up.
Not too bad for a 1953 truck!
53 Chevy Pickup
Old 03-25-2017, 12:25 PM   #380
jkeating1
jkeating1's Avatar
Re: Plus Five
Especially one with 5" spliced into the doors!
jkeating1 is offline   Reply With Quote
Old 03-25-2017, 01:00 PM   #381
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Plus Five
Looks REALLY nice!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-25-2017, 01:27 PM   #382
Flysocal
Re: Plus Five
Very nice sir
Flysocal is offline   Reply With Quote
Old 03-27-2017, 04:04 AM   #383
Nut Case
Nut Case's Avatar
Re: Plus Five
Donandal
You concepts and execution is offffffffff! the charts, When I come on this site I look to for you updates. Strong Work!!
I would venture a guess you could earn a few BIG coins selling these quality trucks.
Thanks for sharing.
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 03-27-2017, 08:00 PM   #384
donandal
Re: Plus Five
Thanks guys,
Today I messed around with the doors.
I put sound deadening inside the door skins and then
started putting the hardware on the doors.
I put the handle and bearclaws on and put the striker plates on.
It closes very nice.
Also put in the vent windows and stainless window trim.
53 Chevy Pickup
Old 03-28-2017, 06:41 AM   #385
dug224
dug224's Avatar
Re: Plus Five
Door gaps are incredible! Well done. I have door gap envy...
dug224 is offline   Reply With Quote
Old 03-30-2017, 03:22 PM   #386
donandal
Re: Plus Five
quick shot of the vent window deflector...
53 Chevy Pickup
Old 03-30-2017, 03:42 PM   #387
donandal
Re: Plus Five
I installed the roll up windows today. Kind of tricky to get
it in there but it's in with out scratching the glass.
The track along the vent window side is a bit snug fitting.
I wiped on a little silicone spray into the felt channel and
that helped quite a bit. It's still a little stiff rolling it up
and down, but I think it will break in OK.
The black rubber wedge trim slides in a channel in the door.
That was a pain to get installed.
I used 3M black weatherstrip adhesive on the felt strips along
the lower window trim and it worked great!
The vent window track lower bracket bolts to my door brace.
The stop also fastens to the brace.
53 Chevy Pickup
Old 03-30-2017, 03:48 PM   #388
donandal
Re: Plus Five
some more photos,
53 Chevy Pickup
Old 04-02-2017, 05:29 PM   #389
donandal
Re: Plus Five
finished the installation of the interior door latches
and handles.
I used bear claw latches and modified the trip mechanism
to accept the actuator rod following the channel in the door.
The flat rod they supplied worked great with the original
handle rod. I slotted the holes and this allows the handle
to travel to the original lock detente. That allows a little more
security preventing the door from being accidentally bumped
open.
53 Chevy Pickup
Old 04-15-2017, 09:44 PM   #390
donandal
Re: Plus Five
Well, no pictures today, but a pretty big day.
We had nice weather this morning and all the guys were around.
No more excuses. We pushed the truck out of the shop, got 4 gallons
of fresh gas, three fire extinguishers and the rest of the fluids and
fired it up.
I primed the oil pump then cranked it without fuel or engine
computer hooked up. It had 50 psi just cranking. Then I hooked
up the fuel pump and turned the key on. Pump worked fine so
time to fire it up.
It started on second crank of about 10 seconds. Settled right down
to a smooth idle and sounds great.
We filled the tranny up and it seems to shift ok thru all the gears and
wants to move in forward and reverse so all seems good.
I managed to get the power steering filled without overflowing and
put about 14 and 1/2 quarts of coolant in the system so I think most
of the fluids are in.
I'll need to fire it up and go thru the whole break-in process when we
get more nice weather but at least its been warmed up.
No leaks anywhere so far.....
Sweet!
53 Chevy Pickup
Old 04-15-2017, 11:04 PM   #391
oldman3
oldman3's Avatar
Re: Plus Five
Congrats, ready for more great updates...Jim
oldman3 is offline   Reply With Quote
Old 04-16-2017, 03:19 AM   #392
Nut Case
Nut Case's Avatar
Re:
Donandal
WOW! Again off the charts, great idea on the adjustable connection between the handle and the latch.
When you where fabbing the doors and cab, did you use a sacrificial rubber weather stripping between the cab and doors to get the door closing and latch all working well with each other and straight, level and plumb, getting that behind you before you get into paint?
I envy your skills and ideas!
Keep on keepin on
NC
Old 04-16-2017, 11:54 AM   #393
solidaxel
solidaxel's Avatar
Re: Plus Five
Good News, just like you planned it !!
I must have missed the break in procedure, where did you find it!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-16-2017, 01:21 PM   #394
mongocanfly
mongocanfly's Avatar
Re: Plus Five
Always makes you feel warm and fuzzy on the inside when it fires off for the first time...
Old 04-16-2017, 05:48 PM   #395
donandal
Re: Plus Five
Pages 6 and 7 have my instructions for the engine for break-in, and the
shop that installed the rear end gears and posi are going to do some
sort of break-in for that too.
53 Chevy Pickup
Old 04-16-2017, 05:52 PM   #396
donandal
Re: Plus Five
Yes it does!
I had a real concern with the fuel lines since they were sort of a pain
and I had no experience. I very happy I had no fuel leaks.
53 Chevy Pickup
Old 04-16-2017, 06:03 PM   #397
donandal
Re:
Originally Posted by Nut Case View Post
Donandal
Keep on keepin on
NC
I used pieces of the old gasket to check the fit somewhat, but I expect
I'll still need to adjust the doors after I put the last weatherstrip
pieces on.
My old gaskets were reproduction ones that were torn up a bit when
I removed them, and they were 5 inches too short to really check the
entire fit.
53 Chevy Pickup
Old 04-17-2017, 08:52 AM   #398
solidaxel
solidaxel's Avatar
Re: Plus Five
Did you receive a "Book" with your engine, was it in the crate, or did you purchase a manual?
How did you monitor your oil pressure before you started the engine the first time?
LS 3 4L70E
Old 04-17-2017, 01:38 PM   #399
donandal
Re: Plus Five
not a book really, but about 20 some page booklet of instructions was
included in a folder with engine/transmission instructions and emission
decal and tuning CD.
I used a separate oil pressure sending unit from classic instruments
that independently supplies their oil pressure gauge that I used in my dash.
I disconnected the computer and fuel pump before cranking it as the
instructions said, then after a couple of turns I had oil pressure of about
50 PSI. Then I reconnected the fuel pump only, powered the pump on
without cranking and looked for leaks, then hooked up the computer and
fired it up.
53 Chevy Pickup
Old 04-18-2017, 12:19 AM   #400
solidaxel
solidaxel's Avatar
Re: Plus Five
Thanks I can do that!
I have a oil gauge screwed to the oil bypass on the side of the pan, but have not turned the engine over
It did not say to pressure the system until the rocker arms have oil before turning the engine over?
So with the starter motor only you have good oil pressure, did it come right up to 50# ?
LS 3 4L70E
